Cost...ring & pinion install?
Old Nov 1, 2004 | 05:02 PM
LD85's Avatar
LD85
Default Cost...ring & pinion install?
I will pull the Dana 44 off of the car and take it to someone for 3.54's to be installed what cost should I expect for the install only?
TIA
Old Nov 1, 2004 | 05:42 PM
bogus's Avatar
bogus
to set the gears into the pumpkin? I would think about $300.00.
Old Nov 1, 2004 | 06:43 PM
STL94LT1's Avatar
STL94LT1
I would say around $200-250. I paid $350 for a complete turn-key install of my 4.10's.
Old Nov 2, 2004 | 08:03 AM
LD85's Avatar
LD85
Thanks I'll see what I can find, $200-$250 seems reasonable
Old Nov 2, 2004 | 08:46 AM
SLOWRIDE's Avatar
SLOWRIDE
Old Nov 2, 2004 | 09:47 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Alright... I'm confused... I called a local (reputable) speed shop in St. Louis MO that said it would be $1400 to set up the rear with 4:10's. That is the reason I opted not to get gears. I know TPIS sells the gears for $475... is there a difference in what I wanted vs. what you guys are discussing? I would have delivered the rear end (whole batwing) and reinstalled it myself.
FYI ~ I called some other shops that were around $1100-$1200 for the same thing, but I've heard some stories about them also.
What gives???
Old Nov 2, 2004 | 10:02 AM
scorp508's Avatar
scorp508
Originally Posted by kwik_ta
What gives???
Sounds like the shops didn't realize you'd be bringing the differential to them. Or they just wanted to pork you.
Old Nov 2, 2004 | 10:09 AM
STL94LT1's Avatar
STL94LT1
Default Caves Springs
kwik', I paid $300 for a new set of Dana OEM 4.10's, and paid First Capitol 4X4 $350 for the complete install.
Old Nov 2, 2004 | 10:18 AM
CFI-EFI's Avatar
CFI-EFI
Or they just didn't really want the job. Do these outfits do gear work? Or would they have to farm it out. Most general repair shops don't perform gear work, in house. Keep calling, and make sure you communicate well, with what you want from them. You carry in the diff? Who supplies the gears? Is a case needed? Bearings? Who supplies? Make things extra clear as to what you want or need, and they understand and quote accordingly.
RACE ON!!!
Old Nov 2, 2004 | 10:59 AM
LD85's Avatar
LD85
3.54's are $375 here
www.ikerds.com
Old Nov 2, 2004 | 03:52 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
TIA
Earlier this year I paid $600 for a local corvette-speciality shop to remove the diff', swap the gears (that I had bought elsewhere), rebuild the posi unit and then reinstall the whole thing. The only injury I risked was the posibility of a vicious check-writing sprain - Which I avoided by using my check-card.
And again, that was a corvette-speciality shop (Tidewater Corvettes). They had to reposition the shimms 5 times (from what they tell me) but they worked into the price the time it would take to do it right, so there was no suprise at the end. I was quoted $600, and I paid $600. Anybody who quotes you $1400.00 doesn't want your business.
Old Nov 2, 2004 | 04:52 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You got a bargain. I phoned around the San Diego area last year for the same service (drive the car in, drive the car out) and the normal price was $1200. They supplied everything, including all labor.
Larry
Old Nov 2, 2004 | 04:59 PM
kwik_ta's Avatar
kwik_ta
That's who quoted me the $1400!!! I originally thought to take it to Bier Brothers but my neighbor had his 10 bolt set up by them and it whines pretty bad. Where did you get the gears from? Maybe I need to call First Capital back and clarify my situation...
Old Nov 2, 2004 | 05:15 PM
STL94LT1's Avatar
STL94LT1
Chris, check your PM box.
Old Nov 2, 2004 | 05:22 PM
Strick's Avatar
Strick
Let's make sure we're talking "apples and oranges" here.
1) first case is turn key operation. They supply the gears, bearings and all the labor. Est $1200
2) you bring them the differential and the gears, and maybe a rebuild kit for dif. Est $300
3) you bring them the differential and they supply everything else.
Est $650
Old Nov 2, 2004 | 06:58 PM
LD85's Avatar
LD85
Decent prices here
http://nationaldrivetrain.com/shopsi...tml/page2.html
Old Nov 2, 2004 | 08:30 PM
silver & red CE's Avatar
silver & red CE
I bought gears/install kit for $300, dropped the diff, took it to shop, paid $200 labor.
Eric
To Cost...ring & pinion install?
Old Nov 2, 2004 | 08:34 PM
zelement's Avatar
zelement
Larry
Larry, I think here in So. Cal prices are way higher then anywhere else.
I paid $1100, and I bought the gears and bearings.
I brought the car and the gears to the shop and they did it.
That is the going rate with all of the tuners here.
If you want them to supply everything be ready to pay $1500.
Old Nov 2, 2004 | 09:10 PM
MrCrowley's Avatar
MrCrowley
I just set mine up myself and it was a pain in the azz! I had to make a custom preload pinion shim, and trial fit it SEVERAL times before it was right. The pinion nut has to be torqued to 200ft-lbs with the proper preload. The shim alone cost me 60.00 bucks. So do remember you get what you pay for. There was no crush sleeve on my d44 and I wanted mine perfect. Trust me you don't want a half *** job and have something come apart when you are going very fast!
Old Nov 2, 2004 | 10:32 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
www.ikerds.com
Hey Buddy,
Ikerds is OK in my book.They built the rear end for my 86.Except for a front seal that leaked in about a year of use(an easy fix),there were no other problems with the rear end work.They seem to know the C4 rear ends very well.You can usually see them at a Big car show or Vette show with their parts and display.Heck theyre not too far from Indy either to go visit.
Good Luck and Ill be in touch soon.
