O2 Sensor Location
Old Nov 3, 2004 | 09:43 PM
bigjack's Avatar
bigjack
Default O2 Sensor Location
I've experienced a "wandering idle" problem on my '85 with a new engine and recalibrated prom. Stumbling thru the Tech Tips I found a Tip re. replacing the OEM O2 sensor with a HEATED one. Apparently some owners have experienced a rich condition at idle due to faulty readings from an improperly placed sensor on their Hooker 2149 headers.
Before I replace the sensor @ $50 with a heated one, has anyone experienced the same problem and solution????? Thanks, Jack
Old Nov 3, 2004 | 11:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Before you replace the O2 sensor, use the ECM's Field Service mode (described on my site) to see if the ECM is going closed loop and staying there.
But usually a wandering idle is due to a vacuum leak or to a problem with the IAC.
Old Nov 4, 2004 | 12:51 AM
vader86's Avatar
vader86
Replacing with a heated O2 will probably not fix a hunting idle problem.
You need to do a TPS reset and IAC cleaning/reassembly first.
To O2 Sensor Location
