installed (spark) plug depth - effect on combustion?
Old Nov 4, 2004 | 08:16 AM
Red Tornado's Avatar
Red Tornado
Default installed (spark) plug depth - effect on combustion?
I also posted this in the engine mods section.....
I have AFR (CNC'd with TPIS' program) heads, AFR says the plug reach required for AFR heads is 5/8" (.625"). I'm looking into using shorter header plugs, the Accels are .420", which is .205" shorter.
AFR says these are too short. TPIS says they're fine. Naturally, I'm confused.
What effect will .205" less depth have with combustion & performance?
Old Nov 4, 2004 | 09:00 AM
comp's Avatar
comp
never leave threads exposed in combustion chamber For sure
Old Nov 4, 2004 | 09:18 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Comp,
That is not what he is asking? If AFR recommends a minimum depth for the plug into the cylinder and the accels are less than the minimum there will be no threads exposed on either, but the accels will not stick as far out into the cylinder. How does this effect combustion?
Old Nov 4, 2004 | 10:38 AM
90NormZ51's Avatar
90NormZ51
Default Plug Reach is the threaded portion
Are you talking about the plug's reach, the threaded portion of the body, or the length of the center electrode of the plug? These aren't the same thing. If the plug's reach is too short it will expose the threads in the head, which comp pointed out correctly is bad. Exposed threads can serve as hot spots and can increase the likelihood of detonation.
Now if the unmodified AFR head uses .625, but if TPIS's CNC program cuts into the plug boss in the chamber making it shorter, then TPIS's recommendation may be correct. Confirm this them not us.
To installed (spark) plug depth - effect on combustion?
