[READ!] Warning regarding AC Rapidfire Spark Plugs!
Old Nov 4, 2004 | 10:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
Had the same problem with ny #5 R.F's and Msd wires. I would rather know they were good and tightly sealed than loose. Can't win em all, especially when we deviate from stock. I don't think these parts are bad, but personally next time I'll be putting my ignition parts back to stock. Maybe my tach will start acting normal again.
Old Nov 4, 2004 | 10:51 PM
comp's Avatar
comp
wow this is Short Thinking on their part
Old Nov 4, 2004 | 11:30 PM
Red Tornado's Avatar
Red Tornado
Lone Ranger, I have the Rapidfire #5/Taylor 8mm Spiro Pro combination and have absolutely no problems regarding too tight a fit....maybe its because I have the "earlier design" Rapidfires since I have a '90?
Old Nov 5, 2004 | 08:37 AM
rick lambert's Avatar
rick lambert
Good heads up
Old Nov 5, 2004 | 12:19 PM
96GS#007's Avatar
96GS#007
I put RF12s in my LT4 earlier this year. They work fine.
Old Nov 7, 2004 | 05:09 PM
TwoFast4Lv's Avatar
TwoFast4Lv
My vote goes to the NGK camp. always dependable and with some of the new sensing coil packs still ECM/PCM friendly
Old Nov 8, 2004 | 10:01 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I'm running Moroso wires and the regular "El Cheapo" Autolite plugs...no problems for a year now.... good luck
Old Nov 8, 2004 | 12:32 PM
Ricks94vette's Avatar
Ricks94vette
Default AC Rapidfire Spark Plugs
I've never used these but the problem seems to be directly related to vacuum within the boot. I mean, the plug boot is creating a vacuum inside and the harder you try to pull the boot off, the stronger the vacuum becomes. May I suggest inserting a volt meter(the one with a small needle point) or similar tool into the top of the boot, pulling it to the side thus creating a very small hole which should release the vacuum inside the boot. Hope this works.
Old Nov 8, 2004 | 03:50 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
Originally Posted by Lone Ranger
If it happens again, maybe I'll let you take a shot at it since I'm so incompetent
WOAH! Not calling anybody incompetent here.. I even said it happened to me a few different times in the past with different plug and wire combos... Just sounded to me like you jumped on AC delco for a poor design to something that can happen to just about any plug... didn't mean to get you ruffled up I'm sorry.
Old Nov 8, 2004 | 05:17 PM
Lone Ranger's Avatar
Lone Ranger
I wasn't really ruffled up. Anyhow, everything is good and right again, have a new set of Moroso Blue Max wires installed, and the car is running very well w/ them.
Old Nov 8, 2004 | 10:14 PM
No Go's Avatar
No Go
I've run the Taylors and RF's for last 3 years...~40,000 miles...no problems.
Moroso ranks right up there with Mr Gasket though...
Old Nov 9, 2004 | 08:18 AM
Lone Ranger
What's wrong with Moroso?
Old Nov 9, 2004 | 03:17 PM
  #33
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
the wire boot was thoroughly coated with di-electric gel prior to installation. The fit is so tight.
Are you absolutely sure you didn't grab the SuperGlue instead of the dielectric????
Larry
