ZR-1 DFCO Disabling
Old Nov 5, 2004 | 06:13 PM
ZR1forFun's Avatar
ZR1forFun
Default ZR-1 DFCO Disabling
My 90 ZR-1 backfires on the overrun with headers
installed, it's driving me nuts.
What table/parameter in the .bin file needs
to be changed to stop the backfiring, I can't
see anything relating to DCFO?
Old Nov 9, 2004 | 09:24 AM
Carl90's Avatar
Carl90
Checking the 90 ZR1 8EA ECM in TunerCat...I do not see any way to adjust decel realated parameters (timing or fuel).
If you get an answer, please post it.
Carl
Old Nov 9, 2004 | 12:32 PM
Tyler Townsley's Avatar
Tyler Townsley
Both sides? Get a WB O2 and see what the AFR is doing. It sounds rich, leaking injectors or too rich in the WOT tables.
Tyler
Old Nov 9, 2004 | 08:58 PM
WVZR-1's Avatar
WVZR-1
Carl,
Good to see you hanging around! That sounds similar to what mine did/does from time to time!
Dave
Old Nov 10, 2004 | 03:55 PM
ZR1forFun's Avatar
ZR1forFun
That's what I found too. But Marc Haibeck does a custom chip which eliminates the backfire with headers. I haven't a clue where the decel parameters are. Does TunerCat only show a limited number of the tables?
Maybe Todd Pepmeier, ZR-1 cal guru could help out. I'll try e-mailing him.
Tyler, it's not an AFR problem per se, my friends ZR-1 started backfiring after headers were installed, he and I both have stock engines.
I'll let you know what I find.
Old Nov 10, 2004 | 08:16 PM
Tyler Townsley
Everything is an AFR problem. AFR tells you what is going on. Is it too rich too lean, its where do you start.
Oh yeah. He is a link that shows what you are talking about on a 90 ZR 1 calibration.
http://www.sirgalahad.org/tyler/misc/dcfo.jpg
Tyler
Old Nov 10, 2004 | 10:43 PM
MrCrowley's Avatar
MrCrowley
Try adjusting it in TunnerPro.
Old Nov 11, 2004 | 03:45 PM
ZR1forFun's Avatar
ZR1forFun
Just got the solution.
I e-mailed TC at TunerCat with my problem and he sent me the latest definition files for the $8E and $8EA ECMs. These allow access to the DFCO parameters in the ECM constants table.
I plan to try disabling the DCFO function by adjusting the parameters appropriately.
Old Nov 30, 2004 | 08:18 PM
stano's Avatar
stano
JR at TeamZR1.com can help for sure
Old Dec 2, 2004 | 05:48 PM
ZR1forFun's Avatar
ZR1forFun
Thanks, I reprogrammed the chip myself and it works great, no backfire anymore and the car drives much more smoothly without the DFCO.
I might try contacting JR
To ZR-1 DFCO Disabling
