dead battery
Old Nov 5, 2004 | 10:37 PM
csfiredawg77's Avatar
csfiredawg77
7th Gear
Default dead battery
1986 C4 every 4-5 days without starting I have a dead battery. I replaced Alt, Starter and new Battery. The person I bought the car from said it was in the dash. All clusters refurbished, problem still occurs. Has anyone had this problem or suggestions.
Old Nov 5, 2004 | 11:28 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
All the time. I`m on my third battery, & 2nd alternator since May. If I leave the doors & hatch open to listen to the radio when I clean my car, the battery will go from fully charged, to fully dead within 20 mins. My only solution so far was to put an on board battery charger on the car, & keep it plugged in when I am not driving it. It was $39.00 at National auto.
Old Nov 5, 2004 | 11:29 PM
bmalec's Avatar
bmalec
Well, let me preface this by saying I've never tried to diagnose a problem like this, but with that said, I'll throw out a suggestion
Grab a multimeter and measure the current draw from the battery to the positive battery cable when the car is off and the key is out. Then, start pulling fuses and recheck the current draw after each fuse is pulled.
I think that would help you isolate where the problem is. I'm sure someone else will chime in with a better idea
Ben
Old Nov 5, 2004 | 11:45 PM
SLOWRIDE's Avatar
SLOWRIDE
Old Nov 6, 2004 | 07:25 AM
rick lambert's Avatar
rick lambert
That was very well put-by doing the above you'll find out where the draw is.
Old Nov 6, 2004 | 08:54 AM
mitchcole's Avatar
mitchcole
Ben
It's easy. Pull the fuse, stick you amp meter between the two terminals and look at the value.
When you find on that's high - trace out that circuit. It's the best way to start.
Old Nov 7, 2004 | 08:36 PM
csfiredawg77
7th Gear
Default Thanks
I appreciate the tips. Any help I get on this forum is greatly appreciated.
To dead battery
