Cryogenic does it work?
I have read many studies that showed increased life of tooling from these above mentioned industries, but never took part in a study at our facility to the usefulness of it.
The purpose or theory behind the cryo is that ANYTIME you alter machine/alter a metal component, you induces stresses to that material/component. Through doing so, you are giving the part a stress riser, or a head start to a location that a failure could begin. The purpose of cyroing doesn't really make the material any more strong, it basically is used to "relieve" these stress area, through a series of very cold cycles that allow the material to realign its internal makup in a fashion that ultimately relieves its stresses and makes it a more robust piece, that will usually last longer.
Also there is NO harmful effects of doing cyro to a piece, it can only make it better. So worst case, is you wind up with a equal piece, but best case is you wind up with a piece that is better.
That is the 2 cent explination of the process
Sport Compact Car was running a Nissan Sentra SE-R a few years back at the 24 hours of Nelson Ledges.
They were running cryo treated rotors, they held up so well, that they lasted the entire 24 hours.
I think the hardness issues has more to do with the material in question. Some materials get stronger from the process, others, release tension that might weaken them. Subtle difference, for sure.
In the case of the rotors, they got stronger. They didn't wear. I don't have pics, cause this was 10 years or so ago!
As ski said, it can't hurt anything other than your wallet.
Think about this: the normal stress relieving and hardening processes accomplish their goals by putting energy (in the form of heat) into the metal. Cryo removes heat/energy, in effect stopping all changes while at the lowered temperatures. When the part regains room temp it should be in the exact same state as before the process.
Cryo may work on aluminum because some aluminum alloys will exhibit a phenomena known as aging, and will harden at room temperature, gaining strength. Maybe this is why they respond to cryogenics. Ferrous alloys do not age-harden.
That said, many people swear it helps certain parts (brake rotors being one of them) and if they like it, who am I to argue with their results.
Larry
code5coupe
Larry
code5coupe
I can't argue with emprical data. Eye witness data.
That's my point...
YES IS DOES!
do the ring and pinion! and the casing!
i can go ring and pinion for 150!
let me know. i can tell you more if need be.
Email me asap.
I am soon to be a supporting vendor.
thanks alot your friend
Sean
slimshaby@mindspring.com
cryo treating any moving part of you engine will resist wear, corrosion and rust!
cryo changes the texture make the metal stronger!
rotors last alot longer. as for miles each rotor is different but i can say it will about double the life of them!
and cryoing the entire engine will add about 30-70k to it... this is just from what people expirence. it is impossible to be exact!
but that is from ym expirence
any one need anything coated?
email me
your friend
Sean
email me
your friend
Sean
also I would recomend cryoing the ring and pinion and pumpkin! and then the bat wing you can powder coat! that would give you a strong long lasting combo!
honestly cryo treating all moving parts would be best but not many people other than most race teams would do this.
it does prolong the life of and keep it stronger the entire life of the metal part!
thanks alot
your friend
Sean
thanks alot
your friend
Sean
what price range for cryoing a complete pumkin?????
ring and pinion I have changed for CF members its $138.
was $150!
let me know if you need any coatings!
thanks alot
agian
your friend
Sean
was $150!
what other parts are in the pumpkin otrher than the ring and pinion?
__________________
All iron and steel are alloys with carbon, chromium, molybdenum, vanadium, nickel, silicon, etc. in specific proportions. As the alloys cool from the molten state, they crystallize in particular forms depending on the alloy and cooling rate. Using a microscope, one can see the crystalline structure. To simplify slightly, the alloy and cooling rate determine the crystalline structure, and the crystalline structure ultimately determines the hardness, toughness, brittleness, etc of the part.
After the part is cooled, the crystalline structure can be modified by reheating to a specific temperature, and cooling at a specific rate (annealing, tempering, hardening) The surface can be modified by chemical treatment to modify the structure chemically (case hardening or nitriding (Tufftriding). Finally all alloys evolve their crystalline structure over time even at room temperature. Aluminum alloys do it faster than iron alloys.
Cryotreating accelerates the crystalline evolution of the alloy to the ultimate structure, which as it happens is harder than the original. (The usual technical term in iron alloys is martensite transformation into pearlite) Pearlite is a submicroscopic arrangement of Ferrite (iron) and cementite (iron carbide). The iron carbide gives hardness, and the small grain structure gives toughness. Again, this will happen over long time at room temperature, but cryotreatment accelerates and makes uniform the process. So much for tech talk. It's actually much more complex. Some alloys benefit more than others, and some parts may be adequate without treatment.
The structure can be verified microscopically. This means that cryotreatment has an objective means of measurement. (One could also do strength tests). In other words, it's not just hocus pocus.
Hope this helps in understanding the process.
