Help! Red Hot Shorty Headers
Old Nov 7, 2004 | 07:44 PM
GRX's Avatar
GRX
Default Help! Red Hot Shorty Headers
When reving at about 2000-2300rpm for about 1 minute my headers (1985 shorty fac headers) will glow medium red. The engine is stock except for AFR 190 heads, TRW 8.7:1 comp. ratio forged pistons and a mild Crower cam: Specs at .050” tappet lift:
Intake: Duration: 209*
Exhaust: Duration: 217*
Intake:
Opens at: -5.5 ATDC
Closes at: 34.5 ABDC
Exhaust:
Opens at: 46.5 BBDC
Closes at: -9.5 BTDC
Lobe Lift:
Intake: .330” x 1.5 rocker= .495”
Exhaust: .343” x 1.5 rocker= .515”
Lobe separation: 114*
My AFR during this is about 14.7:1.
Any ideas?
Old Nov 7, 2004 | 07:47 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default glowing
when my headers started to glow I had a timing problem. Fixed the timing and the glow went away. Hope this helps.
Old Nov 7, 2004 | 08:12 PM
GRX's Avatar
GRX
Forgot to mention that timing adjusted stock.
Old Nov 7, 2004 | 08:25 PM
James94LT1's Avatar
James94LT1
I had glowing headers when my cam was a tooth off.
Old Nov 7, 2004 | 08:33 PM
GRX's Avatar
GRX
Cam is on right. I've checked that before. I was thinking that maybe my custom cam has a bit too much lift on the exhaust valve (.515"). Exhaust valve is large too at 1.65" dia. There is no valve overlap this cam is mild except for the lift.
Old Nov 7, 2004 | 08:37 PM
GRX's Avatar
GRX
...Engine has about 2 hours on it...garage time.
Old Nov 7, 2004 | 09:26 PM
Jloshotz's Avatar
Jloshotz
Do you have cats? Just a thought...
Old Nov 8, 2004 | 12:16 AM
redbullapril23's Avatar
redbullapril23
afr is off. if you havent gotten custom tune. and u have heads and a big ol cam . get it!
you7r friend
Sean
Old Nov 8, 2004 | 07:38 AM
runner140*'s Avatar
runner140*
Default Usually when the headers get red...
Thats usually a symptom of a clogged header, could it be that simple.
Old Nov 8, 2004 | 08:50 AM
GRX's Avatar
GRX
Cat is not clogged- I've checked. Headers are not clogged- happens on BOTH sides of motor in every pipe.
Old Nov 8, 2004 | 08:55 AM
GRX's Avatar
GRX
you7r friend
Sean
I do my own tuning. AFR is 14.7 (+/-.3) to 1 during this.
Old Nov 8, 2004 | 01:36 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Seems like you have covered the bases. I'd try running it without the cats on and see if it does the same thing... Just to be sure it is not the cats.
Old Nov 8, 2004 | 02:05 PM
CFI-EFI's Avatar
CFI-EFI
I had seen this post before but hadn't stopped to read it. I was prompted by your plea in the Engine section. I decided to reply here to keeping it from getting spread over two forums. Glowing headers are caused by air fuel mixture burning after the exhaust valve opening. Often a rich mixture that wasn't fully consumed in the cylinder is one cause. A lean mixture, because it burns hotter than normal, CAN cause it too. Either mixture condition, and even a correct mixture can cause this if the timing is retarded. Retarded timing lights the mixture late and it finishes late, in the headers/manifolds. You have checked the cam timing, the ignition timing, and the A/F ratio. Something you checked is off. Without tearing it back down to verify the cam timing, the simplest thing to check for is the ring on your damper having moved to give you false readings. It HAS to be one of the items you've verified. Your cam is waaaaay mild, as is the compression ratio. No problems, there.
RACE ON!!!
Old Nov 8, 2004 | 08:46 PM
GRX's Avatar
GRX
Thanks for your help!
To Help! Red Hot Shorty Headers
