I have a 1995 corvette with the lt-1 engine "no mods" I can't get it to start. It is getting fuel so it is not the fuel pump. Could it be a sensor or something of that nature "vacuum leak" Where would be a good place to look?
What is it doing when you crank the engine?
Lt1's do that kind of thing from time to time.Check the fusses.
At the fuss box and next to the battery.
Do the lights work?
Need More Input.
Try locking and unlocking both doors with the key.
Check coil and ignition module, too. I had a crank, no-start condition on my LT1 and it turned out to be a bad coil which fried the ignition module, too.
