Need some help!! with winter performance mods...
1988, 4+3, 3.07 gears, 71000 miles.
The mods I currently have are: 2149 Hookers with Y-pipe, Random Tech Cat, Flowmater catback, frisbee tossed, K&N with Cutlid, Screens cut from MAF, CentreForce Clutch, and Nitto 275/40/17.
With the above mods last month I went 13.78@100.47 MPH with a 1.99 short time, with no tuning at all. The weight of my car with half tank of gas, spare still in tact, and me weighing around 190 LBS, The car weight in at around 3550 give or take.....Estimate of current HP and Torque at the crank is approx. 285/390, But the problem is the car has nothing past 4700, Which is where I was shifting at if my mem is correct.
So anyways, These are the mods I have planned for the winter:
-1.6 RR's(10CHP, Allready bought the Bowtie LT-4)
-AFPR,Timing,Cutback Plugs(Should free up 10CHP)
-crank pulley, wires, airfoil, T-Stat(10CHP)
-was and still might siamese, and port runners,pleneum,base(15CHP)
I am not sure if my CHP is about right or now, but that would equal around 45CHP, and raise me up to around 330/410 I would assume, and I was hoping with those simple mods that dont cost alot, It would bring me down into the 13.3@105MPH range with a 1.9* short time. I was hoping anyways.
So the question is what to do? I was also thinking of the SR. But does it work on a near stock L-98 that I have. My goal is to run in the high 12's for next year. Can I do this without doing the cam, and heads? If i get the SR, Is it necessary to port it? Should I keep with my 113 heads?
And the questions go on, and on.......And to let u know, I have also thought of a 75-100 shot of N.O.S. I would think with that alone, I would be running high 12's, but what like to go N/A route first.
So what would u do if you were me, Remember I am on a budget. So taking the motor out and rebuilding it, is not an option. Hope you guys can help me out, Thanks!!!
BTW, It is snowing here in Barrie, ONT today.
No one else wants to post?
but do u think i am about right with my expections?
I would also suggest a 160deg T-stat & fan switch.
You may hit the MPH goal but will likely need a line lock to hook up well enough to bring down the short time to drop ET.
so 330/410 isnt possible....huh!
o.k. thanks! didnt know about the 330, but since i am around 390 allready, figures 400 plus is realistic.
You will not get those HP numbers with those mods. I wouldn't do a rebuild yet because your motor is just a baby. If you really want to go fast for cheap, put a nitrous kit on it. The only mod I would do on your list is the 1.6rr. Save your money and buy an SR intake, heads, and cam. In the meantime you can use nitrous to satifisy your need for speed and to spank people.
I've used the same equations on a night when I got some dyno pulls just after passes down the 1/4 mile rwhp agreed very well with calculated chp, assuming a 17% DT loss with my A4.
So, if Rick can add 30chp (which I think is realistic) with intended bolt ons & tuning he will be building about 310chp (or maybe more), in the same weather as his prior runs. That should put him through the traps at around 103.5mph with an ET potential of ~13.1sec. Of course that will take a short time of low 1.8s or even high 1.7s.
It's true that if he does the siamese intake base it will cost some low end it will give him around 20chp more at 5,200rpm; since he has a stick shift that should be no problem. I changed to a 2,000rpm TC (from the stock 1,500rpm TC) when I did the siamese base and still it much improved my short time as well as upping my shift points.
Your probably making about 280 hp and 360 ft/lbs or less (flywheel). Rear wheel your probably making about 230 hp and 310 ft/lbs
It takes some engine work for a 350 to make 410 ft/lbs.
i am not trying to be rude sir.....talk to guys on the forum, i am far from that.
when i was stock the car dyoned 252/372 at the crank, i am at work so i dont have the RWHP numbers, but it was around 219/325....around that, so i estimated with my mods i gained around 15 foot pounds, that's all.
i think i have made a decision tonight on my mods...
i am going to do all the mods i mentioned above with the expection of, i am going to port the heads, 2.02 valve, and install the rockers which should be good for an extra 25-30CHP. i would imagine with all that, it would be good for high 12's, and if i do the 100 shot of NOS i would think i would be able to run low 12's.....
this is the plan anyways....
and then move to heads/cam since youve already done LTs. stg heads from percison is 1k and a good cam is a couple hundred! Anywhere in there, better if done moding, Id get a custom tune to take full advantage of all your newly earned power! with a tune and all that done you could see a 10-50 hp or tq diff!!
just my 2 cents!
best of luck and dont take my bowtie 1.6 rrs hahaha
jk
best of luck man
your friend
Sean
Metallurgist in disguise.
just my 2 cents!
jk
best of luck man
your friend
Sean
