Lean Problem
Old Nov 9, 2004 | 10:09 PM
GRX's Avatar
GRX
Default Lean Problem
Ok, here goes. If the car sits for a long time (days), the car starts fine...warms up...runs at a perfect/approx. 14.7:1....although the headers get cherry red at about 2000rpm.
Ok, next day, start the motor, warms up and goes to 15:1...16:1...17:1....18:1. That's when I shut the motor off.
I have swapped ECMs. Has a new MAF. Fuel pressure is adjusted.
Timing set. Everything is pretty much new or verified.
Anyone care to comment? TIA!
Old Nov 9, 2004 | 10:18 PM
bmalec's Avatar
bmalec
I'm assuming the wideband isn't hooked to the ECM; if that assumption is correct, can you see what the other O2 sensor is telling the ECM?
Ben
Old Nov 9, 2004 | 10:19 PM
SunCr's Avatar
SunCr
What year? Modified MAF/throttle body? How are you measuring fuel ratio? Off hand, injectors may need cleaning or there's a header/vacuum leak, but these are just guesses. What do the block learn cells look like at 2000 rpms? Is the lean condition unique to one side?
Old Nov 9, 2004 | 10:32 PM
GRX's Avatar
GRX
Its a 1985. AFR meter is measuring off a welded bung about 4 inches downstream of stock O2 sensor. Both sides of exhaust read the same.
Would a vacuum or exhaust leak cause this? ...but it runs fine if it sits for a long time.
Old Nov 9, 2004 | 10:49 PM
SunCr's Avatar
SunCr
Either leak sucks in air which is unmeasured by the MAF.
Old Nov 10, 2004 | 02:46 AM
comp's Avatar
comp
O2 reads air it goes LEAN is what i have seen...????so it make's it fat..
that is lemp mode...
Old Nov 11, 2004 | 11:06 AM
GRX's Avatar
GRX
Forgot to mention that NO CODES are set during this...
To Lean Problem
