Brake fluid ?
Doing a little research, apparently some people have had this problem due to low brake fluid. I looked at the brake fluid but the level is only a smidge low(right under the max line). Is there any other things it oculd be?
P.S. I was looking at the fluid and it looks pretty nasty, probably the original stuff put in there. Is there a good procedure for changing and flushing all the fluid out other than doing it through the brake lines?
A thorough bleed of the system is in order. The nasty fluid itself could be the cause of your problem. Best way to flush the system is the bleed process. You can do this yourself or get a good shop to do it. It takes four or five cans of brake fluid to do the complete job. Most shops may not want to spend the time it takes and may just bleed enough out so the fluid in the MC looks clean.If you can get the car up in the air and the wheels off, you can do your own GRAVITY bleed
E mail me if I can be of further assistance
Jack
