Density Altitude--DA?
Old Nov 10, 2004 | 05:20 PM
sothpaw2's Avatar
sothpaw2
Default Density Altitude--DA?
? How do you calculate that, directly from the Barometric pressure?
Or does everyone look it up from the National Weather Service or something?
I would think the best times to race would be when the Barometric pressure is high, temp. cool, but with low humidity. Am I right?
Old Nov 10, 2004 | 06:35 PM
jfb's Avatar
jfb
Here's a site that calculates density altitude for you.
http://www.csgnetwork.com/densaltcalc.html
Old Nov 10, 2004 | 06:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Right you are, DA is the effective altitude based on weather conditions.
The hard core racers often carry weather stations that not only calculate DA but also predict ETs based on DA and prior passes.
Old Nov 10, 2004 | 08:50 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by sothpaw2
? I would think the best times to race would be when the Barometric pressure is high, temp. cool, but with low humidity. Am I right?
You are right. I get mine from my weather station. There likely is a standard, but different weather station makers use different algorithms to calculate the DA. My Autotronics usually reads 600-700 feet different than a friend's Tag unit, even though the weather data is the same. I know mine has been calibrated, and I think his has been, too. We're usually talking DAs of over 6000 feet. The exact number isn't as important as a constant source of the information.
Old Nov 10, 2004 | 11:48 PM
Jet-Jock's Avatar
Jet-Jock
For future reference, density altitude is affected by pressure, temperature, humidity.
Low pressure, low temp, low humidity = low density altitude.
Opposite would be high.
So instead of your elevation being say 1200 feet above seal level, and those variables are mostly high, you may acutally be at say 1500 feet above seal level (density altitude). When the air is less dense, a high density altitude, your performance goes down because there is less air to compress (manifold pressure will be down).
Turbo charging the engine will remove most of the effects on performance as a result of density altitude.
Old Nov 11, 2004 | 09:04 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
This is the unit that most guys use. Its reasonably affordable and accurate. ~425 dollars.
It will calculate your DA, predict your runs etc.
Jetjockey. you will STILL see gains and losses with turbo and other powder adder setups, with changes in DA. Its not the "air" your seeing changes in, its the oxygen content of the air.
With low DAs there is more oxygen per cubic foot. Hot air can hold more water (humidity) which displaces the oxygen, and makes you run slower. Cold air conversely, has a harder time holding water (humidity), which allows more oxygen. Then Barometric pressure, plays a role also, which basically you can think of it as in higher BPs, its packing the oxygen tighter, which affords more oxygen to be present.
From our experiences, the humidity plays a larger role than anything else. Changes in the humidity often cause more changes in ET than other factors. BP is usually also a big player, but through the coarse of the day, it usually stays pretty steady. I mainly see BP changes from one track to another, which is usually cause of its physical reference to sea level (altitude). Closer to Sea level - higher the BP.
Hope that explains it to you better.
Jesse
Old Nov 11, 2004 | 12:55 PM
Jet-Jock's Avatar
Jet-Jock
Yep sorry I didn't get into real specific details as to why a specified volume of air is affected by DA. I just listed the components that affect DA, and a generalization or characterization of the effects.
To Density Altitude--DA?
