Still Doing The Same Thing
Old Nov 10, 2004 | 08:59 PM
CHBING76's Avatar
CHBING76
Default Still Doing The Same Thing
O.k. I Changed The Cat , Plugs , Wires , Cap , All The Tune -up Stuff + The O2 Sensor , Timing Seems To Be Ok,but Car Will Still Bog Out And Not Run Rigth , Help Me Please !!!
Old Nov 10, 2004 | 09:01 PM
gbody5's Avatar
gbody5
Year? Any trouble codes?
Old Nov 10, 2004 | 09:04 PM
mikey whipreck's Avatar
mikey whipreck
what year what engine and what conditions?
Old Nov 10, 2004 | 09:06 PM
chriswtx's Avatar
chriswtx
Did you check your fuel pressure under load?
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
I don't remeber if I replied to any of your previous posts, but just in case... I had a"bog" problem for quite awhile(it would even quit running at stop lights sometimes)...I did all the things you need and finally traced it down to a bad fuel pump. AFter I replaced it..it ran perfect!
Old Nov 10, 2004 | 11:07 PM
jfb's Avatar
jfb
Connect a hose to your shrader valve on the end of the fuel rail and connect a fuel pressure gauge to it and tape it to the bottom of your windshield. When it bogs, if the fuel pressure drops, your fuel pump or fuel pressure regulator or fuel filter may be defective.
Old Nov 11, 2004 | 12:03 AM
CHBING76's Avatar
CHBING76
sorry<the year is 1984 and the car was sitting for about ten years. i think ??? , it has something to do with the muffers, they sound clogged , i changed the cat but did'nt make that much of a diff.
To Still Doing The Same Thing
