383 In and running
Block: LT1 .030 over with splayed mains
Rotating assy. Scat 4340 3.75 crank, Scat Pro line 4340 6’’ H-beam rods, SRP forged pistons, and Fidenza aluminum FW. (LT4 HD timing set)
Heads/Valve train AFR 195 comp ported by More performance W/ Ferrea valves, titanium retainers Comp springs and Comp Pro Magnum 1/6 R/Rs W/guide plates and hardened pushrods.
Intake: LT4, ported by More performance and bored for 58mm TB
Cam: CC 306 (Small Base circle)
TB/Injectors: Holley 58mm TB / FMS 36# injectors
Exhaust: Stainless works LT headers, no cats and Magna Flow mufflers.
Ignition: Delteq
Keeping it cool: Be cool radiator and Meziere HD electric WP
Ignition: Delteq
Who's tuning it?
Did you do all the assembly work yourself? How much was the parts cost + block machine work, if you don't mind me asking?
Block/Machine work (Including splaying the mains) $600 plus $120 for ballancing
The rotating assy was $1500 Crank, Rods and pistons
Heads $3000 (Comp porting included)
LT4 intake $260 plus $150 for porting
Single Mass w/fidenza $800 (Dont remember exactly but it is close)
Comp Rockers $260
Rebuild kit (Gaskets, oil pump, ARP head blots, Lifters, ect..) $500
Cam $280
Thats the big stuff I can remember but am geting a bit dizzy looking at the cost of this thing and have no desire to add it all up for a total
Comp Rockers $260
Cam $280
From your experience, should a newb such as myself even attempt an engine build in the garage, or pay a pro to do it?
Don't get me wrong, I'd love to just jump in head first and start bolting stuff together, but because of the amount of work involved in pulling and reinstalling the engine, not to mention the significant cost in components, I'd want to make triple sure that it had been assembled correctly.
more pic's
