Need suspension / steering help
Old Nov 11, 2004 | 01:39 PM
Red90Coupe's Avatar
Red90Coupe
Default Need suspension / steering help
This problem is on my daily driver (98 GMC Sierra PU) not my Vette, but thought someone on the forum might point me in the right direction. Steering is acting a little wierd at times, not constantly. It is a little hard to explain...... but here's my attempt. Sometimes when going into a long, sweeping curve the steering will seem as if it has too much power assist, in that the steering wheel will slightly move toward the direction of the curve and there will be no feeling of "steering response" for a second or two. By "steering response" I am referring to the feeling of opposite pressure of the steering when turning, but when this happens that feeling disappears and the steering wheel feels like there is alot of play in it for a couple of seconds, but then comes back.
Could this be my PS pump going bad, or possibly a rack/pinion problem?
Thanks.
Old Nov 11, 2004 | 02:15 PM
subman's Avatar
subman
I've had similar probs with a 99 Suburban. Try the following link.
http://www.fullsizechevy.com/
They, like CF, have helped me with challenges and questions.
Old Nov 11, 2004 | 05:30 PM
Red90Coupe's Avatar
Red90Coupe
Thanks for the link. I didn't know there was a forum for fullsize GM's. I'll take a look. Bet it's not as good as this one though
Old Nov 12, 2004 | 12:42 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Sounds like the steering wheel postion sensor on the column for the variable effort steering. Seen it several times.
To Need suspension / steering help
