I'm discovering MSD finally, need some help.
Old Nov 11, 2004 | 07:22 PM
Light84vette's Avatar
Light84vette
Default I'm discovering MSD finally, need some help.
My HEI Distributor screwed over, long story. Anyway I have that dist, and then I have the old style dist from non HEI that I can use which I was thinking about till I seen this History channel. They said that the MSD allows the spark plug to fire more then once, allowing everything to get burned, probably means more efficient and they said better idle.
Now what do I need so I can get the old style Distributor to work with MSD, I will probably buy this stuff off ebay b/c I see no point in paying retail when I can find it cheaper. I already wasted tons of money like that. Anyway, after I get it running again, maybe around the beginning of summer, I'd like to go with forced induction.
Which one should I buy that will be able to do vacuum advance and then be able to do boost retard when that variable comes into play later on? Or would I have to buy a totally seperate unit?
Old Nov 11, 2004 | 07:24 PM
comp's Avatar
comp
go to their site,
Old Nov 11, 2004 | 10:31 PM
Blown 96's Avatar
Blown 96
I have a MSD 6AL for sale it is only about 6 months old and dose not have a scratch one it. i will take 125.00 plus the shipping if you want it let me know.
Old Nov 12, 2004 | 11:10 AM
CFI-EFI's Avatar
CFI-EFI
The MSD will come with instructions. Not much of a problem making it work with the distributor. The problem will be making the car work with that old mechanical distributor.
RACE ON!!!
Old Nov 12, 2004 | 11:26 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Uh, yes. Multiple Spark Discharge will do that.
Go for it!
Larry
Old Nov 12, 2004 | 01:50 PM
Nathan Plemons's Avatar
Nathan Plemons
Go to www.msdignition.com They have several products, one of which is a boost timing retard that you could use in conjunction with whatever igntion box you decide to buy.
I would HIGHLY suggest you buy this stuff new. I have personally had fantastic luck with all of my MSD products but some people have not been so lucky. Buying new with a warranty may pay for itself in the long run.
Old Nov 13, 2004 | 03:27 PM
Light84vette
Okay thanks guys, I found a schemetic Diagram of the 6A series and It doesnt seem too complicated to install. Anyway thanks for the help guys.
Old Nov 13, 2004 | 04:14 PM
amswak's Avatar
amswak
as a side note, I love msd! I installed some new spark plug wires and like an idiot was not careful and 4 of the wires fell on the headers! Burned them down to the insulating core...I called MSD, told them what I had done, and wanted to see if was possible to buy individual wires instead of the whole set. The guy told me to send my whole set to them and they would replace them for free!!
Old Nov 13, 2004 | 04:35 PM
CFI-EFI's Avatar
CFI-EFI
Does that schematic tell you the proper volts for the points? How to power the coil in the start mode? What will you use to supply pulses to the ECM to fire the injectors or activate the fuel pump relay?
RACE ON!!!
Old Nov 13, 2004 | 05:52 PM
Light84vette
No Injectors, No ECM, and No need to find a source to provide Power to the Fuel Pump. I am running a 750 Vacuum Secondary Holley ontop of a 406CID SBC, so I dont have to worry about that.
To I'm discovering MSD finally, need some help.
