Jack placement
Old Nov 14, 2004 | 02:42 PM
John Robinson's Avatar
John Robinson
Default Jack placement
I wanted to take off my right front wheel on my 93 Coupe to check the brakes today. Got out the trusty floor jack and crawled under car where it said to put jack. All I could find to put jack under was the very edge of the frame were the body meets it any further in and I would have been on floor pan. Is that the place to put the jack on that thin ledge????
Old Nov 14, 2004 | 03:01 PM
Wayne88's Avatar
Wayne88
Take a look at that ledge- its solid and is part of the frame.
I don't jack it there, I go further into the frame.
Old Nov 14, 2004 | 04:54 PM
Mo_Bandy's Avatar
Mo_Bandy
I agree it's better to go to the frme if you can, I have also used a floor jack on the lip just catching the lip and not the floor board
Mo
Old Nov 14, 2004 | 05:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When using either the floor jack or the stock jack I mostly just jack at the points indicated by the arrows under the rocker panels.
I recently did front & rear brakes and used those points for the floor jack when removing the wheels. Of course the puck on my floor jack has the cross slots so that it cannot slip in/out and risk taking out the floor boards or rocker panel.
Old Nov 14, 2004 | 05:52 PM
XQIZT's Avatar
XQIZT
if you're just lifting one corner, i lift where indicated by the arrows. but when i but the whole car up, i lift midway on the door, under the trailing edge of the mirror. with the z51 package, the car just comes right up. if you go under that lip you run the risk of hitting brake or fuel lines (depending on the side)
Old Nov 14, 2004 | 08:23 PM
C10 JDR's Avatar
C10 JDR
no idea - but why didn't I think of that screen name??
Old Nov 14, 2004 | 10:01 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
i can't jack it on that ledge without damaging the rocker panels. It dings em and pops the paint off. I dont even care anymore now.
Old Nov 15, 2004 | 11:47 AM
HammerDown's Avatar
HammerDown
Ha! Yeah, mine are like that, too. I had a couple of stress cracks in mine from where the car shifte slightly and the rocker panel lip dropped down into the cup of the jack. I don't car anymore, either. You'd have to get down on your stomach to see it anyway.
I put a hockey puck in the cup of the jack now and that seems to save the rocker panels. They still bend, though.
To Jack placement
