Tunning?
Old Nov 14, 2004 | 04:42 PM
rtracy's Avatar
rtracy
Default Tunning?
Do most of the tunners start out tunning by logging a couple runs in the car with Datamaster? Should I log a quarter mile WOT run and a 65 MPH highway run then go to my Tunercat program and start tunning or should I do it differently? Thanks, Ray
Old Nov 14, 2004 | 05:12 PM
Mo_Bandy's Avatar
Mo_Bandy
I generally do couple WOT runs to about 75 -80 ..."whatever your comfy with and will keep you out of jail!"
i review generally rpm, injectors, MAF, and or MAP, mph, intake temp, coolant temp, ingition timing, the front O2's, spark knock retard and knock count.
I do a WOT run look at the o2's to see how the fuel mixture is and look at timing t see ig any is being pulled from spark knock.. and that's prety much to start...
Mo
Old Nov 14, 2004 | 07:13 PM
rtracy's Avatar
rtracy
Thanks Mo, Anybody else have any feed back? Would it be good to do a part throttle at highway speed?
Old Nov 15, 2004 | 09:58 AM
rtracy's Avatar
rtracy
Any more tuners?
Old Nov 15, 2004 | 10:20 AM
STL94LT1's Avatar
STL94LT1
Default Datamaster/Tunercat
For part throttle tuning I'll run a datalog varying from idle to 3000 rpms for about 20 minutes. Then I'll do my WOT and spark advance tuning on the Dyno using a wide band o2 sensor. Also during the part throttle run I'll do a few WOT take offs just to check for spark retard.
Old Nov 15, 2004 | 10:30 AM
rtracy's Avatar
rtracy
Thanks guys, looks like I am going to do a couple of logs. Don't go far I might need more help after logging LOL.
Old Nov 15, 2004 | 10:39 AM
STL94LT1's Avatar
STL94LT1
Default VE Master
I've had really good results using VE Master for my part-throttle tuning.
http://home.comcast.net/~jgeorger/
Old Nov 15, 2004 | 12:57 PM
rtracy's Avatar
rtracy
I'm useing Datamaster for my scanner and Tunercat for my programer. Speeking of Datamaster, I have e-mailed them 3 times so far with no feedback.
Old Nov 16, 2004 | 12:10 AM
rtracy's Avatar
rtracy
Hey guys! I tried connecting to my car earlier with pcm communicator and it says that it is connected, not loging and I get SYS flashing on my dash. Any idea? I have used the program before and it worked fine
To Tunning?
