new used top ?
Old Nov 14, 2004 | 07:03 PM
Robertuoo's Avatar
Robertuoo
Default new used top ?
found a 1995 top (soft ) My top is shot and older (88) at my friendly salvage shop. Mine a plastic backlite this one a heated glass window. Has anyone replaced their old top with a used one from a newer Vert ? Also wondering Is the frame the same ?
thanks, Robert
Old Nov 14, 2004 | 07:10 PM
chucks88's Avatar
chucks88
Yep, they are the same. I believe there are conversion kits for the glass retrofit. some sort of wiring connector for the defroster I believe.
Old Nov 14, 2004 | 07:32 PM
93convtLT1's Avatar
93convtLT1
yes, I converted my 93 white top to a black top with glass window. There is a kit that you can buy from GM $115 or from Eclers for $125. If you need the part number email me I can look it up. The kit consts of a few plastic blocks and springs, terrible that it costs so much. Once the top is removed the kit requires about 30minites of installation and the top maybe 1-1.5hrs doing it by yourself. Make sure you purchase new weatherstripping
To new used top ?
