Dash lights flicker
Old Nov 14, 2004 | 07:54 PM
Ray Foy's Avatar
Ray Foy
3rd Gear
Default Dash lights flicker
My 92 coupe dash lights flicker especially when the brake lights go on or a fan kicks in. The alternator is putting out about 14 to 14.8. Any ideas about what is causing this will be apppreciated. The ground wire connections I can see look OK. Thanks in advance.
Old Nov 15, 2004 | 12:34 AM
jfb's Avatar
jfb
Remove your battery cables (neg first) and clean the cable lugs and the battery posts and replace (neg last).
The voltage regulator cannot instantly correct for a sudden large current being drawn and can be the reason you see a single flicker when a heavy current is suddenly drawn and particularly when the engine is idling since the alternator cannot deliver its rated current. Inadequite cable connection doesn't allow the battery to help pick up the sudden load current and is why I recommend you clean your battery connections. Even so, you may be a bit sensitive to flicker and if the connection cleaning doesn't fix it you may just have to suck it up!
Old Nov 15, 2004 | 10:30 AM
Aquaman92's Avatar
Aquaman92
Default Dash flicker
I have a 92 vert with 16000 miles and mine flicker too.New battery
and all the connections look good .So i am not to to concerned.
Old Nov 15, 2004 | 11:20 AM
ittlfly's Avatar
ittlfly
I'm just living with it. I both the alt. and battery are just fine. It may be just dirty grounds but I haven't had the time to clean them yet.
Old Nov 15, 2004 | 11:56 AM
Ray Foy's Avatar
Ray Foy
3rd Gear
Thanks for all the great feedback. I plan on changing the battery and cables soon and will let you know if it improves.
Old Nov 15, 2004 | 12:42 PM
mikey whipreck's Avatar
mikey whipreck
You know theres a tech tip on this page that explains what the cause may be and how to fix it?
To Dash lights flicker
