how do I discharge the A/c system?
Old Nov 15, 2004 | 04:19 PM
redbullapril23's Avatar
redbullapril23
Default how do I discharge the A/c system?
i am removing the evaporator core i need to know how to Discharge the a/c!
thanks
your friend
Sean
Old Nov 15, 2004 | 04:22 PM
aeronautica86's Avatar
aeronautica86
take it to an a/c shop
Old Nov 15, 2004 | 04:26 PM
redbullapril23
car is not running. its apart. does any one know how to do it?
thanks alot
your friend
Sean
Old Nov 15, 2004 | 04:56 PM
mikey whipreck's Avatar
mikey whipreck
Legally... you can only take it to an A/C shop
...r12 (freon) escapes due to leaks, which is when it needs recharged...
...you could always 'make' a leak, just by loosening a fitting somewhere
Old Nov 15, 2004 | 04:59 PM
redbullapril23
would that be safe though? my car hasnt been running for 3 months. and its cold outside. if it started leaking would the pressure blow the fitting off?
thanks alot your friend
Sean
Old Nov 15, 2004 | 05:01 PM
ZylaRace's Avatar
ZylaRace
Legally you can't vent it to the atmosphere. EPA would love to bend you over and clean you out.
Where are you located? What is in your system, R12, or 134a?
Do you plan on putting it back together later?
Old Nov 15, 2004 | 05:03 PM
mikey whipreck
Sean
Hmm... I'm not sure, I never tried it. I would def wanna make sure its safe first... The systems are pressurized
Old Nov 15, 2004 | 05:06 PM
comp's Avatar
comp
they sell Bags, it fills off of the shrader valve,, it is EPA ok'ed
Old Nov 15, 2004 | 05:26 PM
LPDesRoche's Avatar
LPDesRoche
If you are just going to vent it to atmosphere, just loosen a fitting until you hear it hissing and leave it alone until it stops. It will not blow off. If you plan on using your AC again when the car is back on the road I suggest you go to an AC shop and have them evacuate the system and see if they will store it for you. Otherwise when you go to refill the system you will get bent over. R12 is very expensive, and I am not a fan of R134 in a system designed for R12. It works but never as good as it once did.
Old Nov 15, 2004 | 05:30 PM
ZylaRace's Avatar
ZylaRace
Please don't vent R12. If the car is down @ Emory I may be able to help you.
Old Nov 15, 2004 | 06:11 PM
redbullapril23
dang no hissin!! i took the whole Ac out. i think what happened was that when i was messing around a couple weeks ago with the evaporator core, i started it up and i had left one of its sensors undone! and white cloud of bad smelling stuff was coming from under the hood. i traced it back to the sensor! and today i removed everything. and absoutely nothing came out not one hiss!
yes i agree i wouldnt do that if its illegal. but i def wouldnt do that because i dont want to hurt the enviroment!!
thanks alot guys
now ill go a little big faster with out the ac lag. and soon im gonna get a new smaller belt to by pass it. thanks agian!!!
your enviromentally friendly Friend
Sean
Old Nov 15, 2004 | 07:45 PM
rsafier's Avatar
rsafier
thanks alot guys
Sean
That A/C System is heavy. I removed my AC & Airpump on my 85, was 46lbs total.
Old Nov 15, 2004 | 10:11 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Hacksaw is the fastest way.
Old Nov 15, 2004 | 11:32 PM
redbullapril23
first thing i did was tke my swiss army knife cut right through those hoses and then unscrewed and unbolted everything else out. for know the ac compressor is still in with nothing running to it. because ill have to size up the right size belt.
the compressor is the heaviest and the evap core is kinda heavy. im gonna fab up a piece of metal to cover the entrance to the car in the fire wall, where the air came in before.
cant wait..more power and less weight=
thanks Alot your friend
Sean
Old Nov 15, 2004 | 11:38 PM
redbullapril23
i bet with switching to LTs over the stock cast Iron manifolds,
muffler elims, ac removal, and spare tire removal. ive shaved about 100 lbs from my car. good for freebies and some LTs !
Old Nov 16, 2004 | 02:11 AM
CentralCoaster
God NO!!!!!! The trees!!!!! spotted snowy owls are falling from the skies!!!!
Old Nov 16, 2004 | 11:33 AM
redbullapril23
hahah. man i was expecting it to explode. but nothing happened i was like wtf thank god!
Old Nov 16, 2004 | 04:53 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Good post....I am thinking about the same thing here soon...but I am pretty sure mine still has Freon in it...so taking the advise of others i will take it to the shop, but unfortunatley I have the hood and front bumper off so I guess its gonna have to wait.
Old Nov 17, 2004 | 12:19 AM
redbullapril23
yea guys whats the link to get those bags to empty the schreder valve into?
your Friend
Sean
To how do I discharge the A/c system?
