Deleting Error Codes?
Old Nov 17, 2004 | 06:41 AM
cyberblast's Avatar
cyberblast
Default Deleting Error Codes?
Hi
I've got the Error Code 22 (Throttle Position Sensor Low). I adjusted now the Voltage from 0.27 Volts to 0.57, but the error is still stored. I pulled the ECM Fuse for 15mins, but no success. Do i need to disconnect the battery? I thought pulling the ECM will do the job too. The "Trip" and "Average" werent reset too, where are they stored?
I've got a 86' vette.
Martin
Old Nov 17, 2004 | 06:53 AM
Steel Blue 91's Avatar
Steel Blue 91
Go ahead and disconnect the battery for ~10 min. Should do the tirck unless the TPS or it's wiring is bad. If the code won't re-occurs, you'll need to dig a little deeper.
Old Nov 17, 2004 | 07:32 AM
cyberblast's Avatar
cyberblast
I measured the Voltage with WinALDL, so i hope the wiring is ok to the ECM.
Thank you.
Martin
To Deleting Error Codes?
