All is good, I have not had problems even with the #8 bolt.
(in any case I used over 10 hours of labor!)
The only thing that make me crazy is that I'm not able to put back the 2 metal tubolar brackets that supports the alternator and the AC compressor on my 90.
If I try to bolt on these brackets they hits the new header collector!
Is it safe to discrd it, or I have to fabricate some new designed bracket?
How you managed this situation?
-Beppe-
In any case It seems that the problem is for 89 and earlier C4.
Mine is a 90 and it has (on the top) a big aluminium alternator bracket that I don't know if it's enough to block the alternator in place, or I need the rear tubolar alternator pipe to support it completely...
...But, If GM made this little rear tubolar alternator bracket, maybe it is needed.
About the X brace. Do you refer to the big X brace of the convertible?
If yes, it clears because my X brace is bent to clear the old stock Y front pipe...
-Beppe-
-Beppe-
Yes it is safe to discard these items on a 90. I can't answer for other years since I never tried it on them. But I had the LPE long tubes on my 90 and the braces would not go back o with them either. I ran the car for over 50,000 miles with it like this with no vibrations or flexing problems.
I just put 2149s on my 91. Here's a picture of the bracket I fabbed up for the alternator support. I'll probably make something similar for the AC at some point. Its 1/2" conduit, crimped on the ends and bent to the correct angles.
-Beppe-
Disappointed. The "sound " is like before at idle and cruising... Just bit aggressive at WOT. I think that part of this is the cat converter that is damping all the sound...
-Beppe-
So you are saying I can let it without the rear alternator support bracket ?
You ran 50,000 miles without them?
I correct understand?
Why it seems is safe on a 90 and not on a 89 and earlier, what's the difference? On the old post I linked above, it seems that Skorp is tired of continuing swapping in new alternators...
-Beppe-
I don't think there's a difference between 90 and the earlier ones, I just think some are lucky and some are not. I've heard of some that have run w/out the braces for many miles and others that have broken alternator cases. I decided to make a brace because these cars seem to have enough problems with alternators without having to worry about braces as well.
Did the same thing on my '89 but in brass, it's all I had around. Reused the stock bolt. Also, I don't have a line-lock, but one would be nice.
Bracket needed to be longer than stock because it was bolted to a different place.
Reason: Pictures way too big
The A/C one usually needs you to use one of those metal pipe standoffs that Hooker supplies and an original manifold bolt. Then that brace should get in there.
-Beppe-
I didn't answer up for an 89 because I have never owned one. On the other hand I have done this twice on a 90 and once on a 91 without problems. But to answer your other question, Yes I went 50,000 miles without a hitch.
From what I'd read, it was the people with the air pump eliminator brackets that had problems with the tabs breaking off the alternators, that really needed the back brace.
I've busted I think now 4 alternators due to this.
Problem:
Checked bolts after a 25 miles trip.
loose!
I had to do another 1/2 turn for each bolt!
Im not able to turn down the bolt at #8 cylinder
Any advice to do that?
For how many times I will experience this loosening bolt situation??
