Speedometer re-calibration
Old Nov 18, 2004 | 12:26 PM
rganders's Avatar
rganders
Default Speedometer re-calibration
Can the speedometer on my '95 coupe be recalibrated if I change my rear wheels from 17" to 18". The tire size would increase from 20.25" heighth to 23" heighth. Calculates out to about 68 actual mph when speedometer reads 60 mph. Thanks rganders@netzero.com
Old Nov 18, 2004 | 01:44 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Yes the speedometer can be recalibrated... I'd like to add 'can it be done with a hypertech tuner?'
Old Nov 18, 2004 | 02:12 PM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
From what I understand the hypertech programmer can adjust for rear end gears and tire size. You'll need to know the total height of the wheel and tire.
Old Nov 18, 2004 | 02:30 PM
xs650's Avatar
xs650
Your tire diameters don't look right. What sizes are they?
Old Nov 18, 2004 | 03:51 PM
rganders's Avatar
rganders
Got the tire height from some chart (can't remember where). The tires on the car presently are 275 40 17. Thanks
Old Nov 18, 2004 | 03:58 PM
TA's Avatar
TA
I believe that 275/40/17 tires are around 25.7" in diameter. You should be able to find an 18" tire thats pretty darn close.
Old Nov 18, 2004 | 04:50 PM
rganders's Avatar
rganders
I'm new to this part of corvette ownership. I found the chart for tire diameter and apparently I misread it. Looks like I could go to a 285 35 18 (diameter 25.85in) and my speedometer would be off less that .6 mph at 60 mph. Thanks Randy Anders
Old Nov 18, 2004 | 08:07 PM
xs650's Avatar
xs650
Find someone with a GPS with a speed readout and check your speedometer at highway cruising speed. Speedometers usually read a little high, so you could potentially make it more accurate than it is by using a slightly larger tire.
We are picking nits here, but why not?
If someday you don't have you chart handy, tire diameter in inches
= wheel dia + (nominal tire width x aspect ratio)/1270
in your case = 18+(285x35)/1270 = 25.854 inches.
Look like your chart calculates it the same way.
The 1270 is just a finagle factor to convert from mm to inches, account for two hunks of rubber and convert from percent to a decimal number.
To Speedometer re-calibration
