need help with high speed miss..
Old Nov 18, 2004 | 10:43 PM
Z06_BluByU's Avatar
Z06_BluByU
Default need help with high speed miss..
I'm getting a high speed miss on acceleration 4500-5800+
I had a problem where the engine wouldbreak up after being in stop and go traffic for about 20 min. I replaced the plug wires and the coil wire and still had the problem.. I checked fuel pressure according to the helms manual and all was ok.. I tested the injectors and all read within 1 ohm of each other.. Fuel filter is less than 5k miles old.. I thought it was the opti-crap.. and I took that off and saw the bearing was shot.. so I replaced the opti-spark with a new sealed unit GM part right from the dealer.. I also changed the water pump while i was in there.. went for a ride and it felt great.. then I hit it and it rev'ed up fast but broke up around 5200 rpm in first gear.. i left of the gas it switched to second and I hit it again and around 4200 or so it began to have a slight miss.. the miss stated there all the way up until I got off of it..
I also noticed the rear speaker in the car is making a funny static type sound that is loud and stays consistant volume no matter what the volume of the radio is..although the volume of the song changes,,,
wife is not happy with me.. please help!
Old Nov 19, 2004 | 02:22 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Did you check to see if plugs are tight?
Old Nov 19, 2004 | 08:34 AM
Z06_BluByU's Avatar
Z06_BluByU
yea.. they are all on tight..
Old Nov 19, 2004 | 08:42 AM
ittlfly's Avatar
ittlfly
I didn't see where you checked the coil and or coil driver. A high speed miss can be caused by 1 or both of them.
Old Nov 19, 2004 | 11:46 AM
Z06_BluByU's Avatar
Z06_BluByU
The helms manual test for the coil was pretty simple.. hook up a spark plug tester and see if it lights.. it did.. I understood that to mean the coil is cool.. now how to check the coil driver... I have no idea
Old Nov 19, 2004 | 08:40 PM
Z06_BluByU's Avatar
Z06_BluByU
plugs look good... is there a test procedure for the coil besides jsut replacing it?? what about for the coil driver?
Old Nov 19, 2004 | 08:53 PM
carbonLT1's Avatar
carbonLT1
8th Gear
I have the same problem. I've resolved to believing that it is the ecm sitting in the engine compartment about the battery. the miss is directly related to underhood temps and it INDEPENDENT of coolant and oil temp.
another member suggested on the forum that you might test this by using a hairdrier to heat the ecu to make it malfunction.
Old Nov 19, 2004 | 08:56 PM
chriswtx's Avatar
chriswtx
What plug gap are you running? Did you try replacing all the plugs. Could be a bad one, wrong gap, fouled plug(wrong heat range).
Start with a new coil and plugs. The coil could check out OK at idle but could be weak at the higher rpm range. I have seen this before with the coil being strong enough to pass the sparkplug tester but weak enough to have a high speed miss.
Old Nov 19, 2004 | 09:08 PM
ittlfly's Avatar
ittlfly
I think there is but I don't have it off the top of my head. Let me check the "bible" before I open my big mouth.
Old Nov 19, 2004 | 09:19 PM
FD2BLK's Avatar
FD2BLK
What gap did you set the spark tester to? I can't remember what the gap needs to be but it needs to be a the corect gap or the test will pass even if the coil is weak. BTW I have an extra coil and module if you need to borow it send me an e-mail and I will send it to you. BTW I also have a strange miss but mine is only at one RPM range 3900-4100. I can hold it at 3750 all day with no miss and at 4200 also with out a miss but if I hold it right at 4000 it has a severe miss. I am hoping my problem is tuning and will find out for shure tomorrow. Good luck and drop me a line if you need to use the coil
Old Nov 19, 2004 | 10:42 PM
Z06_BluByU's Avatar
Z06_BluByU
email sent.. I didnt set the gap on the tester (i didnt even know it had a setting). The plug have less than 5k miles on them.. they are the ac delco platnium plugs as specified for the LT1 (gap and all).
Old Nov 19, 2004 | 10:51 PM
chriswtx's Avatar
chriswtx
Our testers at work dont have adjustments. They are made so it takes at least 48,000 volts to jump the gap.
Old Nov 19, 2004 | 11:52 PM
bogus's Avatar
bogus
stupid question... fuel filter or pump? The speaker static makes me think the fuel pump could be to blame...
Old Nov 20, 2004 | 10:33 AM
ittlfly's Avatar
ittlfly
To check your coil driver , there is a procedure in book #2 page 6E3-A-75. If you don't have a Helms, I'll send you an IM with my # as there is to much to type. ....if your stillwanting to test the driver.
Old Nov 20, 2004 | 10:52 AM
Nathan Plemons's Avatar
Nathan Plemons
It's very possible that the platinum pucks have come off of your AC Delco plugs and you're trying to jump a much bigger gap than you need. IMHO platinum plugs are a complete waste of money. Go spend $11 on a set of Delco R44LTS plugs and you'll be set for another 30k miles.
Old Nov 20, 2004 | 01:16 PM
Corvette0096's Avatar
Corvette0096
That is what I was thinking. Same thing was happening on my brother car on the dyno. Pump could no keep up at 4500+ Car would go lean. That was with a new fuel filter. Time for a new pump.
To need help with high speed miss..
