I'm a moron....
Old Nov 19, 2004 | 09:26 PM
bogus's Avatar
bogus
Default I'm a moron....
ugh...
I donno how many remember that yesterday, I posted that my door locks did not work.
So, I proceed to test, assuming that after all my tests are done, the circuit was bad. I then bypass the bad circuit, making the locks work.
Fine.
Last nite, I find that the horn don't work!
This morning, I tear back into it... this time, I re-read the aux fuse panel... someone, long long time ago, put a 10 amp fuse into the door lock spot... and I miss read the block - text above the fuse in question. I cut the wire for the VATS!!!!!!!
So, today, I undo my beautiful repair, and make another beautiful repair, replace the blown fuse and head about my day... but that killed 2 hours of testing.
One final question: Who the hell designed that cars electrical system? What a convoluted cluster **** that is... jeez... the relays? Not enough slack to get them out of their mourings to test the wiring... And then, it's nearly impossible to get them back onto their brackets... argh.
Oh, well. All good. Everything seems to be working.
Old Nov 19, 2004 | 09:33 PM
94Polo6Speed's Avatar
94Polo6Speed
BTW, the electrical system was designed so you had to bring it back to the dealer for repair.
Old Nov 19, 2004 | 09:34 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Originally Posted by bogus
ugh...
Thats the important part. Its always an adventure working on our cars.
Old Nov 19, 2004 | 09:37 PM
bogus's Avatar
bogus
no. I have a helms manual. makes me smarter than them... or so I thought.
But, the manual did help me determine that yes, the Anti-Theft had nothing at all to do with the lack of function of the door locks...
Old Nov 19, 2004 | 10:37 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
So long as I'm in town I can swing by and give you a hand.
Old Nov 19, 2004 | 10:53 PM
blkblt97's Avatar
blkblt97
I was jut wondering thee same thing about the electrical designers. I just replaced my EGR Temp switch. The connection for the wire is down below the distributor. It looks impossible to disconnect and reconnect the wire without taking the distributor cap off and possibly removing the distributor. I showed it to a local vet shop and they said that to leave the car and they could do it in about 2 hours. I told them no thanks, spliced the wire, soldered it and heat wrapped it in about 10 minutes. Happy days again, no more Code 32.
Old Nov 19, 2004 | 11:49 PM
bogus's Avatar
bogus
it's all fixed now, but thanks! And your welcome at anytime, dude!!!
Old Nov 20, 2004 | 01:38 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
don't know if I should or
Old Nov 20, 2004 | 06:27 AM
Steel Blue 91's Avatar
Steel Blue 91
I think the answer is that the design engineers completed the overall vehicle then it was up to the electrical engineers to 1. make it work and 2. make it fit (or vice versa).
Old Nov 20, 2004 | 08:19 AM
Red Tornado's Avatar
Red Tornado
Hey Andy, glad you figured it out
Don't feel bad, I do silly crap like that all the time
Old Nov 20, 2004 | 05:42 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've been turning wrenches professionally for 30+ years and seldom a day goes by when I don't stop and say, "What the hell was I thinking?" It seems to be getting worse as I get older. 20 years ago, I thought I just about knew it all, but now.... me just gets dumber every day!
Old Nov 20, 2004 | 08:35 PM
CFI-EFI's Avatar
CFI-EFI
It is only what you learn AFTER you know it all, that counts.
RACE ON!!!
Old Nov 20, 2004 | 09:10 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
.......We all kind of take turns around here.......
.......It was just your turn..........
Old Nov 20, 2004 | 10:13 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
ugh...
Fine.
EFI(Engineered by F***ing Idiots) That's all I have to say
Old Nov 20, 2004 | 10:34 PM
92corvette's Avatar
92corvette
[QUOTE=bradvette]Hey Andy, glad you figured it out /QUOTE]
Andy??? Bogus???
Old Nov 20, 2004 | 10:59 PM
JCD's Avatar
JCD
After touring the plant in Bowling Green, I can honestly say that the cars were designed to be built easily, but were not designed to be repaired (it takes them all of five seconds to install the main wiring harness, cheaters).
Old Nov 21, 2004 | 12:09 AM
bogus's Avatar
bogus
Andy??? Bogus???
Uh, yea. It's my name... don't wear it out.
To I'm a moron....
Old Nov 21, 2004 | 12:58 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Dude... I've made worse mistakes... I always tell people one of two things.
1. I have never been acused of being smart and today isn't going to be the first day...
2. I'm not as dumb as I look...
At least you were able to 'waste' time and fix your problem... I unloaded a car at a junk yard only to find out that I just needed a $5 part to get the car to start and run perfect... now that is dumb luck. At least I can blame it on the fact that I was 18 years stupid and it was a POS Mitsubishi Mirage... And I got the car for $50... so I didn't really loose my a$$
Old Nov 21, 2004 | 01:53 AM
bogus's Avatar
bogus
My biggest fear with a stupid problem, is that it will cost me more money than I have (and since I am unemployed right now, that ain't much of trick) to repair!!!!
It is a good thing I have lotsa tools... and time to kill!!!! The last thing I want is to have to take my Vette over to the local Chevy stealer and have their morons work on it... I have the Helms manual... and a nice Fluke meter... and the Grace of God to keep me from going bankrupt!!!
Old Nov 21, 2004 | 11:41 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
