Zf 6spd Tranny Oil ???
Old Nov 19, 2004 | 10:28 PM
6spd's Avatar
6spd
Default Zf 6spd Tranny Oil ???
What Was The Oil Weight That You Guys With The Zf Tranny?? I Think It Was Made By Bmw??
Old Nov 19, 2004 | 11:20 PM
LD85's Avatar
LD85
www.zfdoc.com
Old Nov 19, 2004 | 11:28 PM
94Polo6Speed's Avatar
94Polo6Speed
Castrol TWS 10-60. BMW dealers carry it.
Old Nov 19, 2004 | 11:48 PM
6spd's Avatar
6spd
okay thanks
Old Nov 20, 2004 | 10:07 AM
Kaae's Avatar
Kaae
Default 1989 6 Speed Gear Oil
How often should i check it, and when should i change it?
Old Nov 20, 2004 | 01:48 PM
6spd's Avatar
6spd
well when did you check it?? and did you ever change it??
Old Nov 20, 2004 | 04:44 PM
RichS's Avatar
RichS
I change mine every spring. I now use the Castrol fluid and it seems to help but it's hard to compair since I have a new trans.
Old Nov 20, 2004 | 05:08 PM
James94LT1's Avatar
James94LT1
I just changed mine an put in Redline MTL. It is actually noticably smoother shifting. Probably cause mine was never changed in 76k
Old Nov 20, 2004 | 05:42 PM
Brian Blum's Avatar
Brian Blum
I would only use the GM stuff you get at a dealer, or I've heard the BMW stuff is good too.
Old Nov 20, 2004 | 11:00 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
Okay.. Rockland Standard Gear is the only authorized service center for ZF tranny's in the US and they recommend the GM oil or the Castrol equivalent that you can only get from the BMW dealer ship... Mike from Rockland says that if you use the wrong oil in these tranny's you open up your self to a world of problems because of the differences in viscoscity of oils and how they act adding pressure or not enough to maitain protection... not something you should mess with because the wrong oil can burn up this tranny and cost lots of $$
Mike also said that you should change your oil in the tranny more like every 20-30K miles unlike the GM recommended 50K....
Old Nov 20, 2004 | 11:07 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
[QUOTE=Brian Blum]I would only use the GM stuff you get at a dealer,
The GM stuff is good enough for me...don't forget to add the small bottle of positraction additive when changing differential fluid(hehe )
Old Nov 21, 2004 | 05:05 AM
silver & red CE's Avatar
silver & red CE
[QUOTE=Yello95]
Ouch, I hope you're kidding, this is the ZF6 thread, not the Dana 36/44 thread.
Old Nov 21, 2004 | 05:22 AM
Bans25's Avatar
Bans25
I heard this before about adding posi fluid to the trans (but have never done it..) has anyone else heard that?
Old Nov 21, 2004 | 05:23 AM
Bans25's Avatar
Bans25
I think my manual mentions not to change it just to add to it if it get low!!
Im going to use the BMW oil when I change mine...
Old Nov 21, 2004 | 05:56 AM
ClarenceT's Avatar
ClarenceT
[QUOTE=Yello95]
And the motor too - helps the rings seal. Add it to radiator, and wham, million mile waterpump. That posi additive is a real panacea!
Old Nov 21, 2004 | 10:51 AM
silver & red CE
Originally Posted by ClarenceT
...That posi additive is a real panacea!
I saw the Rev Bob Tilton was selling it along with some actual Jordan River H2O, add it to your radiator and it makes your H2O pump actually add HP!
Old Nov 21, 2004 | 08:43 PM
Perfusion's Avatar
Perfusion
I use the Redline stuff as well... No problems whatsoever.
To Zf 6spd Tranny Oil ???
Old Nov 21, 2004 | 08:59 PM
Atok's Avatar
Atok
This subject has been beaten to death. I'll post this info one more time, maybe one of the administrators can make a sticky for us....
If you check ZF web page you will find:
"Q: What type of oil do I need to use in my ZF S6-40 Corvette transmission?
A: ZF only recommends the following lubricant for S6-40 transmissions. The GM oil (available from GM with part number 1052931) and the Castrol Synthetic Formula RS 10W60 (available from BMW with part number 0751009420)."
Go read for yourself....
http://www.zf-group.com/am/pc/pt/ampcpt03.phtml
ALSO...in the spare parts catalog also on the ZF site...
"All units must use ZF recommended GM Oil (GM Part # 1052931) or Castrol Formula RS 10W60."
http://www.zf-group.com/pdf/S640.pdf
It's a no brainer for me...Castrol goes in mine, replaced every 30,000 miles are recommended by ZF themselves.
Oh, and friction additive in a transmission? I don't think so.
Old Nov 21, 2004 | 09:12 PM
L98 DRIVER's Avatar
L98 DRIVER
don't forget to add the small bottle of positraction additive?
of course you need the posi juice in there it keep the clutch from chattering
Oh jees, I crack my self up
Old Nov 21, 2004 | 09:15 PM
bogus's Avatar
bogus
posi additive? never heard of that... but it is a friction modifer for rather thick oils...
I might just have to get up with Bill on this one.
