PROM chip and diagnostics function
Old Nov 20, 2004 | 10:19 PM
tonymax2's Avatar
tonymax2
Default PROM chip and diagnostics function
I just had the owner of an '88 I'm interested in tell me he thinks the original PROM chip (Mem-Cal or whatever GM calls it) is required for the diagnostic functions to work. He doesn't have the original chip. It was replaced with an aftermarket chip by a previous owner. Anyone out there knowledgeable on this? Thanks, pre-emptivly.
Old Nov 20, 2004 | 11:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Even with an aftermarket chip you can still jumper ALDL pins A&B (the two upper right pins), turn on the key and watch the codes flash or start the engine and the ECM will go into Field Test mode so you can see if the ECM is going into closed loop mode.
Take a paper clip with you next time you check out that '88 and see for your self.
Old Nov 21, 2004 | 03:17 PM
tonymax2's Avatar
tonymax2
The blinking code readout is all I'll probably ever use so that's a relief. I'm not inclined to go to a dealer and pay a bunch to have them hook up their fancy computer-more of a back yard/ under the tree type of mechanic. I'm wondering if the aftermarket PROM chips won't work with an "official" GM service computer like at a dealer due to a propritary ID code or such? What do you think about aftermarket scan tools?
Old Nov 21, 2004 | 03:28 PM
C4Crazy787's Avatar
C4Crazy787
I use EASE PC scan tool http://www.obd2.com/
To PROM chip and diagnostics function
