Cross Drilled Rotors??
Old Nov 21, 2004 | 09:21 PM
bogus's Avatar
bogus
Default Cross Drilled Rotors??
why do we call them that? They are CAST, not drilled... why not called them "perforated"?
Or something like that....
discuss.
Old Nov 21, 2004 | 09:50 PM
LilR3dCorvette's Avatar
LilR3dCorvette
St: Jude Donor '10
discuss.
I just call them cr@p.
Seriously, I've been told by too many other racers to stay away from them, they warp like and crack. No thanx.
I was in a car that had them at a HS event, they started to warp and then they cracked on a fun run.
Old Nov 21, 2004 | 09:53 PM
TA's Avatar
TA
Because the cheap ones are exactly that......cross-drilled.
Old Nov 21, 2004 | 09:56 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I've had good luck with my Eradispeeds.
Those that warped and cracked, what brand were they?
I know the cheapos you find on ebay are better suited as paper weights.
Old Nov 21, 2004 | 10:01 PM
LilR3dCorvette
St: Jude Donor '10
They were Eradispeeds. These guys spend some serious $$$ on their stuff and don't buy the cheap stuff from ebay.
Old Nov 21, 2004 | 10:02 PM
Mr Mojo's Avatar
Mr Mojo
Damn, that's good to know. I haven't taken mine on a road course yet, but I don't do much roadracing, don't have the time. I'll be keeping tabs on mine.
Old Nov 21, 2004 | 10:38 PM
LilR3dCorvette
St: Jude Donor '10
Yeah, they don't seem to do well in the racing department. They got very hot and cracked on a HS course during a fun run. I was in the car when it had a minor spin out the first time. The second fun run, it cracked.
If you don't use them for roadracing they probably are going to be fine. I will say they are damn nice lookin'.
Old Nov 21, 2004 | 10:49 PM
bogus's Avatar
bogus
the biggest problem with C4 brakes are the calipers... the solid aluminum body will spread!!! there are not heat vents in there and the heat causes the caliper to open up and hurt braking performance.
As for rotor warpage... I am suspect to the phrase "warping". From some good stuff I have read, the real problem is transfer of pad material. I wonder what pads these guys are using...
Old Nov 21, 2004 | 11:07 PM
vader86's Avatar
vader86
We call them cross-drilled because most brands are not cast with holes in them.
Baer, Brembo, Wilwood, those are cast with holes.
Old Nov 21, 2004 | 11:22 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Not qualified to discuss, but interested...
Old Nov 21, 2004 | 11:25 PM
Corvette0096's Avatar
Corvette0096
I have a set coming from Sportbrakes. I hope they are as good as the guys in the C5 section say..
Old Nov 22, 2004 | 12:02 AM
LilR3dCorvette
St: Jude Donor '10
I don't recall what kind of pads, but like I said, they aren't novice racers and not using the cheap stuff. I'll have to ask. Many of them strongly cautioned me against running any of the cross-drilled. Just passing on what I've heard/seen happen.
Old Nov 22, 2004 | 12:46 AM
bogus's Avatar
bogus
I find that interesting... you see, most major forms of racing use drilled rotors... er, perforated rotors.
Old Nov 22, 2004 | 12:52 AM
zelement's Avatar
zelement
I gotta call on this one.
Please show pics where this happened. It is true that cross drilled rotors will crack under extreme heat but eradispeed rotors are casts with slots and holes so in reality they are not cross drilled. Because of this they are much stronger and will withstand extreme conditions. The car that your were in and warped and cracked on a "fun" run is complete bs. Eradispeeds are one of the best 2 pc non-ceramic rotors on the market, I have them and run them HARD at many track days never had a problem. I have witnessed many serious road racers with C5, viper, and mustangs that uses the same rotor with tons of power and without any issues.
I would love to see where your buddy's got for powerthat they cracked under a "FUN RUN"!
Old Nov 22, 2004 | 08:48 AM
runner140*'s Avatar
runner140*
Default The name says it all....
The expensive ones are cast with holes in them BUT the cheap ones are drilled . I have a cheap set of cross drilled rotors and have had them for about nine to ten months and they work great--stops well and no cracking, yet.
Old Nov 22, 2004 | 09:41 AM
vader86's Avatar
vader86
Most professionals do use the cross-drilled, but youll find alot of the guys that are into Road Racing and heavy autox will never use the cross-drilled rotors.
Old Nov 22, 2004 | 10:05 AM
LilR3dCorvette
St: Jude Donor '10
To Cross Drilled Rotors??
Old Nov 22, 2004 | 10:32 AM
LilR3dCorvette
St: Jude Donor '10
Oh, yes, I must be making this up. If I don't post pics it must be Just was passing on some info. Geez. Guess I'll in posts like these from now on...
Old Nov 22, 2004 | 01:34 PM
bogus's Avatar
bogus
you made me check my collection of Sebring pics... and you appear to be right.
What I DID see are small, and rather deep, slots. These are limited photos of the C5R over the last few seasons.
But, I know that F1 uses them and Porsche puts them on the 911... Ferrari offers them...
Old Nov 22, 2004 | 01:38 PM
bogus's Avatar
bogus
It's discussion. And I am still trying to swallow the facts here.
I have never heard of the Eradispeed rotors cracking under stresses. And a lot of people here race on them.
It sounds odd that a small cadre of racers, in one part of the country, are having this much problem. Has Baer been informed?
