Whats wrong with using a cam button? I used one in mine along with a roller bearing on the timing set gear. I used a Cloyes hexajust roller timing set and a 2 piece billet timing cover with an adjustible roller cam button built in.
That said, I dont think you can retrofit that to the ols style block. There isnt a machined surface like the newer blocks.
