TPiS Coated Headers...What are U running?
Old Nov 22, 2004 | 06:40 PM
Ivory90's Avatar
Ivory90
Default TPiS Coated Headers...What are U running?
Looking for opinion on fitment of these headers.
Better yet, what type of headers are you running?
Old Nov 22, 2004 | 06:56 PM
90 Convertible's Avatar
90 Convertible
No problem with fitment. I do suggest you make sure the converter will slip on y-pipe before you install it. Also do not tighten the header bolts until the y-pipe is installed. Very tight fit. Drivers side went in pretty easy and the passanger did after I lowered the starter. Hope this helps.
Old Nov 22, 2004 | 07:28 PM
AS84's Avatar
AS84
I'm happy with everything but the coating on mine. After a few years some surface rust showed up around the flange and around the collector.
Old Nov 22, 2004 | 07:52 PM
Ivory90's Avatar
Ivory90
Default Spark plug changes
How does the TPiS headers affect spark plug changing? The advertise easer changing, is this your experience?
Old Nov 22, 2004 | 08:42 PM
Zix's Avatar
Zix
I have the TPIS longtubes on my LT4, I don't know if plugs are easier to change...but it still not too hard. The rear passenger side plug can be a bit of a pain. If I had to do it again I'd get the Exotic Muscle headers, they have a better fir and finish to them IMO.
Old Nov 22, 2004 | 08:44 PM
6spd's Avatar
6spd
I have the TPIS longtubes love them .
Old Nov 22, 2004 | 10:18 PM
VanSpeed's Avatar
VanSpeed
I also have TPIS long tube headers with the Jet Hot coating. I have been running them for about 5 years now. They were are a great compliment to the rest of the modifications to my engine (see sig.).
The coating seems to be holding up fine.
Fit and installations is ok. I have AFR heads and the no. 7 plug was very close to the no. 7 header tube, too close. This required some dimpling to improve clearance, per TPIS recommendation. I also had to file the flange bolt holes for the no. 1 exhaust port as they did not align properly, it was just a small amount of filing. The y-pipe required some cutting and re-welding to get the center section of the exhaust to be centered under the car.
Just my experience.
Brian
Old Nov 22, 2004 | 10:47 PM
1MoorTym's Avatar
1MoorTym
Hookers 2149, great fit. I'm using their Y pipe as well. I did not have any problems with this part, although I've heard some others had fitment issues with A4s.
Old Nov 22, 2004 | 11:46 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Hooker 2151 long tubes with Jet Hot ceramic inside and out
Old Nov 23, 2004 | 03:04 AM
pablocruise's Avatar
pablocruise
Gonna run long tubes on a CA car?
(btw, hooker 2149's here I love them!!! )
Old Nov 23, 2004 | 08:06 AM
LD85's Avatar
LD85
Sometimes fitment depends on the heads that you have too, if you have the L98 plug angle etc.
Old Nov 23, 2004 | 10:13 AM
AS84's Avatar
AS84
The only plug that still hard to get to is #2. Other than that, they're all pretty easy to get to with the stock d port heads.
Old Nov 23, 2004 | 10:25 AM
Red Tornado's Avatar
Red Tornado
Same here as well.
Old Nov 23, 2004 | 03:14 PM
James94LT1's Avatar
James94LT1
They fit on my Lt1 great! I think they did make spark plugs changes easier also! Again this is on a LT1.
To TPiS Coated Headers...What are U running?
