U-joints?
Old Nov 23, 2004 | 02:23 AM
jutammel's Avatar
jutammel
Default Bushings and U-joints?
Hi, I am going to change all bushings to polyurethane versions this winter. I am considering buying the complete set from Corvette Central. The question is does it include ALL bushings or is there other bushings that needs to be changed but are not in the set??
And also I have a question about U-joints. I would like to change them also while I am doing the bushings change. Corvette Centeral cataloque includes half-shaft and drive-shaft u-joints. I know it's stupid question but what U-joints I need and how many
Old Nov 23, 2004 | 02:42 AM
pablocruise's Avatar
pablocruise
The sway bar bushings are a seperate kit because there are different size diameter bars on our cars. The endlinks are included in the sway bar kit. Determine what sway bars you have. Can physically measure them or see what suspension option your car has. The code is under the lid of the center arm rest lid.
U joints? 2 for the driveline and 2 per half shaft. 2 half shafts.
Or did you mean part numbers?
Get the HD Dana ones. They don't have zerk grease fittings on them. That weakens them. Someone here ahs the PN's
Old Nov 23, 2004 | 03:14 AM
jutammel's Avatar
jutammel
Thanks That's the information I was looking for.
To U-joints?
