New 355 still using oil ..
Old Nov 23, 2004 | 09:48 PM
#70SM2's Avatar
#70SM2
Default New 355 still using oil ..
I've had this car for 9 years, 8 spent in a shop playing with mods. I'm not a mechanic/technician, but I did study engineering. Over the years you learn to trust some performance mechanics, but most are bs.
So. I have a new 355ci. 23 degree Trick Flow Street Bracket Kit (about 1800 mi.), Hyperteutetic pistons, Low Tension rings from Speedway (Ringset for Ultramax Piston) on the invoice, part#915-2500030.
Tight Fit Headers ZZ-4 coated. FreeFlow exhaust no emmision stuff.
But still using a quart every couple hundred mi. Some opinions center around engine preasure, Neg. or pos. maybe something to do with old EGR. I'm not sure, any ideas?
Old Nov 23, 2004 | 09:55 PM
Pete K's Avatar
Pete K
Are you running a vacuum pump on the crankcase? I think low tension oil rings require a pump.
65Z01's Avatar
65Z01
Cruise-In II Veteran
I assume you've checked over & under for oil leaks??
What year engine?
How many miles on the engine since rebuild?
Did you use a break in oil?
If no leaks you might check cylinder compression as a 1st step.
Old Nov 23, 2004 | 10:28 PM
#70SM2's Avatar
#70SM2
Default ?
Pardon my ignorance "Vacuum Pump"? I don't think we installed one.
Old Nov 23, 2004 | 10:49 PM
Pete K's Avatar
Pete K
The way I understand them, the pump is belt driven and resembles a factory type smog pump. They put a vacuum on the crankcase to allow the rings to seal properly. I am no expert but am willing to bet a 10 dollar bill that you need to add the pump or swap out the low tension rings for standard tension rings. If you have a Jegs or Summit catalog,you can view the pumps and get an idea what they look like and how they mount.
Old Nov 24, 2004 | 02:04 AM
#70SM2's Avatar
#70SM2
Default Jegs or Summit catalog,you can view the pumps
Thanks, will do!
JAKE's Avatar
JAKE
It's the low tension rings. They're great for drag racing applications, but due an awful job of controlling oil on a street engine.
They're touted to reduce ring to wall drag thereby eliminating a lot of power loss due to ring drag. Tests have shown the ring drag is the biggest parasitic power loss on an engine.
But (isn't there always a "but") even Scoggins-Dickey recommends dumping the low tension ring set that come on some factory engines in favor of a standard tension setup.
5/64ths top and second single moly and 3/16th standard tension SpeedPro SS50U oil ring set is the way to go for a street engine. They may cost a bit of power (bet you'll never know it), but that's far out-weighed by the good seal and reduced oil consumption they give.
Per inch of bore, N/A, I like .045 for the top ring and .055 for the second.
Just my thoughts.
Jake
Old Nov 24, 2004 | 04:13 AM
pablocruise's Avatar
pablocruise
Who did the work?
I did not have the best of luck with speed-pro brand. I chose Child & Albert and filed each one to each cyl bore. Have your builder check the gap of each top and second ring installed in their respective bores. The sets that are supposedly already gapped can be off by quite abit. I've seen it firsthand a bunch of times. No need to skip this important step.
I suspect you will have to pull it all apart and put a finish on the cyl walls again.
Ask Jeff Carroll for recomendation on machinists/engine builders in the SB area. Really nice guy.
He has the alcohol funny car there in town.
www.carrollmotorsports.com
An hour North of you is Foster Race engine service. I hang out with them and they are the cat's ***.
Old Nov 24, 2004 | 12:22 PM
MSR's Avatar
MSR
can't speak for that exact brand/model, but i've used low tension rings successfully in many engines. (as have manufacturers, since most new cars come with low tension rings.)
basics, do you know if the oil is getting past the rings, or being sucked in through either pcv system or valve guides/seals? the first task should be to determine this.
-michael
Old Nov 24, 2004 | 02:26 PM
#70SM2's Avatar
#70SM2
Default I hope a vacuum pump will help
Originally Posted by 89 Paul in Cal
Who did the work?
Wow, I sure hope we don't have to pull the engine apart again! There is 1800 mi. on the motor. Every part is new except the crank, that was perfect and was polished. Import machine shop did machine and balance work. My mechanic Wendal did the assembly and install, he has done alot of hot car motors here. He mentioned that he used the same rings in his 400, and the oil consumption went away when he added the Vortec Supercharger, he also has nos. I sure hope a vacuum pump will solve the problem, I've kinda exceeded my budget already by a lot. I wasn't planning on the new tranny a couple weeks ago, But I gotta tell ya, it's sure fun to drive!
Old Nov 24, 2004 | 10:10 PM
#70SM2's Avatar
#70SM2
-michael
Holy$ht .. the vacuum pump is $400 at Summit!
I'm not sure where the oil is getting past, but yes, I believe it's the pcv system. So I disconnected the pcv. on one side today, hard to tell, so much holiday traffic, everywhere I went some SUV. was lost in front of me. I'll try some 1/4 mi. runs when everyone else is sleeping after 2much Turkey!
Old Nov 24, 2004 | 10:36 PM
SPEED750's Avatar
SPEED750
Does the car smoke like crazy ??
Old Nov 24, 2004 | 10:37 PM
SmokinBlack's Avatar
SmokinBlack
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
#70SM2
Your problem sounds exactly like what we are seeing here with a 406 we just put in a '69 Camero.
By any chance are you using fel-pro head gaskets?
Old Nov 25, 2004 | 04:03 PM
#70SM2's Avatar
#70SM2
Originally Posted by Justin Gillott
#70SM2
Not sure what gaskets, it's all part of the Trick Flow Street Bracket kit. Heads, cam, roller rockers & all gaskets. Unfortunately the only vacuum pump from Summit is $$. I'm sure the engine is perfectly built, the guys are really good.
Old Nov 25, 2004 | 04:11 PM
comp's Avatar
comp
do a leak-down test
Old Nov 25, 2004 | 05:00 PM
CFI-EFI's Avatar
CFI-EFI
And that's only the pump. You'll spend $700.00 to $1000.00 with brackets, belts, pulleys, hoses, fittings, etc. before you're through with the pump. There are several possibilities, but I'm with JAKE on this one. *I* think whoever spec'ed the low tension rings, screwed up.
RACE ON!!!
Old Nov 26, 2004 | 03:16 PM
JAKE's Avatar
JAKE
The main culprit is the oil ring package.
Like having too many cooks in the kitchen, you'll get all sorts of opinions and recommendations.
So here's mine:
After you've done all you can do (and spent lots of $$) and still don't get the results you're looking for, swap the ring package.
First verify the wall finish the shop used then, if compatible, you can change to SpeedPro rings with the block still in the car. Opt for the +.005 version and custom gap them for the bore they'll be installed in.
Changing rings pretty simple once the oil pan and heads are removed.
Probably around a $150 or so for new rings and gaskets.
Jake
To New 355 still using oil ..
Old Nov 26, 2004 | 03:38 PM
#70SM2's Avatar
#70SM2
Default too many cooks in the kitchen
So here's mine:
Jake
The more I hear the more I'm beginning to think you guys are right about the low tension rings. I took off the pcv on one side, no difference .. still leave a lot of smoke in the mirrors.
So you think, if I change out the rings they can be installed without honing the cylinder walls? Still less than 2k.mi. on motor. But has been run pretty/real hard.
Old Nov 26, 2004 | 07:37 PM
Pete K's Avatar
Pete K
If the motor was hone w/torque plates you can swap rings. Check with the ring manufacturer regarding the recommeded finish(stone grit). If the new rings need the same finish, no problem. If they are different hone for sure. That said, I would at least run a bottle brush hone thru the cylinders for a touch up (if it were my motor).
Old Nov 26, 2004 | 08:23 PM
autotech's Avatar
autotech
Find out who the machine shop was. Ask if the block was torque plated, if not, there is your problem. Been thru this... Good Luck...
ps: I do this for a living and have done many many motors before torque plating was used as a norm. You could bore and hone with your eyes closed and make them seal. I bought my 88 and had the motor out 3 times and all the way down trying to get it to seal, wasnt happening, till we torque plated...
