Oil temp sensor
Old Nov 24, 2004 | 10:29 AM
conv90's Avatar
conv90
Default Oil temp sensor
Installing Hooker LT I broke the oil sensor near the Oil filter
I have a 90 and for what I understand the 90 and 91 are different from 89 and earlier.
Someone know where I can buy this sensor?
It's a 3 blade sensor.
In addition:
I don't remember any constant, table or flag in the chip that refers to oil temp, so I'm pretty sure I can run without them... BTW If someone know some reason I have NOT to run without this sensor..
-Beppe-
Old Nov 24, 2004 | 12:06 PM
CFI-EFI's Avatar
CFI-EFI
My Corvette parts book was printed in April of 1989, and shows some 1990 parts, but the oil temp sender listing ends with the 1989, in my book. If it is different 1990 and up, I can't help. However, as long as it isn't leaking, there is no reason for not driving it.
RACE ON!!!
Old Nov 24, 2004 | 12:10 PM
FD2BLK's Avatar
FD2BLK
Good luck, other then a dealer. I got lucky and the 5th parts store I went to had it. The first four told me that ther ewas no such thing, I would just and say damm what about my gauge then
Old Nov 24, 2004 | 12:14 PM
c4cruiser's Avatar
c4cruiser
The display will just show "Low" if the sensor is broken or disconnected. I would go to the dealer for a replacement switch. If it's an AC Delco part, you might try to find it at a AC Delco store or maybe even NAPA.
Whether on not you need the display is another thing. I usually run my 87 at track events with the oil temp display on.
conv90's Avatar
conv90
...If you add that I'm in Italy and I need an Online shop...
here thare are NOT GM "dealer".
To Oil temp sensor
