91 vette.. what should the map sensor read.
Nov 24, 2004 | 11:48 AM
im just making sure everything is working properly, what range should the map sensor voltage be ?
Nov 24, 2004 | 11:55 AM
Quote:
Voltage?
My KPa readings are with stock cam (not you case)
idle in park or nutral: about 34 or 35 Kpa at 775rpm
idle in D with brake pedal on: about 43 or 44 Kpa at 675 rpm
At KOEO: 99,9 kpa
at WOT : up to 99,8 kpa
HTH
-Beppe-
Nov 24, 2004 | 01:06 PM
my scanner shows the map sensor voltage, not kpa. not sure how to convert..
Nov 24, 2004 | 01:09 PM
The voltage should swing between 5V to .5V between full throttle to idle
(shooting from memory)
Chris
Nov 24, 2004 | 06:01 PM
If you are supercharged the stock map will read up to 104 KPA but he above KPA and voltages are correct...
Mo
Nov 24, 2004 | 06:06 PM
Quote:
Mo
Never heard of kpa . What does it mean?
Nov 25, 2004 | 01:28 AM
KPA is Kilopascals it is metric for pressure readings 100 Kilpascals =14.7 psi or atmosheric pressure
21" Hg = ~30 Kpa
18" Hg = ~40Kpa idle
15.5 " Hg = ~50 Kpa
10 " Hg = ~70 Kpa part acceleration
7" Hg = ~80 Kpa harder acceleration
4" Hg = ~90 Kpa vitrually wide open throttle
0" Hg = 100 Kpa WOT
" Hg is inches of mercury
Hope this helps...
Mo
Nov 25, 2004 | 02:54 AM
Since you have a 91 (mine is a 90) you have an $8D code.
The $8D code outputs the MAP sensor ADC counts. This can be converted to a voltage by:
VOLTS = ADC * (5/255)
To convert from ADC counts to KPa I use:
KPa = ADC * 0.369 + 10.415
-or-
(KPa = ADC * 0,369 + 10,415)
-Beppe-
Nov 25, 2004 | 03:51 AM
I would replace it you are running a 150 shot of Nitrous!
With your mods you should be almost in the 10's It's a cheap part and easy to replace.
