no start
Old Nov 24, 2004 | 01:13 PM
blacknblue's Avatar
blacknblue
1st Gear
Default no start
I Bought 88 With 13000 Miles On It. Car Is Basicly New. When Cut Off And An Attemt Is Made To Restart , At Times It Will Appear To Be Dead. All Other Functions Work, Just A Silent Starter. Altenator Is Ok In Fact Battery Shows Full Charge. Just A Touch Of The Jumper Cables And Away We Go. Have Installed New Battery And Condition Still Exsists. Ideas?
Old Nov 24, 2004 | 07:25 PM
JackDidley's Avatar
JackDidley
Sounds like a VATS problem. Have you tried a different key ?
Old Nov 26, 2004 | 03:32 PM
MR.KIDD's Avatar
MR.KIDD
Sounds like what Spankyello said Vats but make sure those battery ends are clean I have had them look ok on the outside but unscrew the terminals out of the cables
and found corrosion.
Old Nov 28, 2004 | 06:39 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would unlock the doors with the key and see if it helps,don't use the pad or lock the doors with the electric lock.
Or you can stand around for a half hour until the vats lets you in.
Old Nov 30, 2004 | 10:26 PM
ebm257's Avatar
ebm257
Check the resistor in each key with an ohmmeter to make sure they are consistent.
The vats system is a pain sometimes.
Install a vats bypass switch.
Maybe that will help!
Sorry!
I hate it when that happens!!!
To no start
