Throttle body question
Old Nov 24, 2004 | 01:30 PM
Lichen's Avatar
Lichen
Default Throttle body question
Last week a had a 52mm throttle body installed (and against the advice of most forum members) had one of those Vortex cold air induction deals installed. Boy, talk about an increase in throttle response! Even chirps the tires in second gear (A4). I have 2 questions. 1) Did I really gain any HP? and 2) Why did the car come with 52 mm intake ports but only a 48mm TB?
Old Nov 24, 2004 | 01:34 PM
mikey whipreck's Avatar
mikey whipreck
Sounds like you have a much more responsive throttle... as opposed to actually gaining horsepower... which I'm told is the biggest advantage of putting on a (new) 52/58MM TB
Old Nov 24, 2004 | 03:42 PM
Red Tornado's Avatar
Red Tornado
thats weird, most all the archives here i've read pretty much say the same: going to a larger Tb will DECREASE throttle resolution, ie, bog down more, when tipping off-idle.
Old Nov 24, 2004 | 05:42 PM
Mo_Bandy's Avatar
Mo_Bandy
My experience was less throttle response as well... It will be interesting to see if your ECM once it reajusts gives you the same results a month from now....
mo
Old Nov 24, 2004 | 09:21 PM
SLOWRIDE's Avatar
SLOWRIDE
Got the same setup on my LT4 I like it. Had for two yrs that way. JMO.
Old Nov 24, 2004 | 10:49 PM
mikey whipreck
hmm... guess i need to reread my stuff then... sorry
Old Nov 24, 2004 | 10:58 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Don't feel bad, I've read it both ways on here too. I wish y'all would get it figured out once and for all so I'd know if I have the best one for my combo!
Old Nov 25, 2004 | 01:34 AM
Mo_Bandy's Avatar
Mo_Bandy
I was also told that a 58 is supposed to be better even though I'm supercharged Im still running the stock TB
Mo
Old Nov 25, 2004 | 02:00 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Every engine is differen't ,now the big ? how cold outside is it right now and what is your mileage?
Remember an engine is just a big pump more air in more air out.
I ported my throttle body and added the air foil.
Not that much more HP but the throttle responds is alot better.
Old Nov 25, 2004 | 08:54 AM
rick lambert's Avatar
rick lambert
Wasn't SKI-DOWN IT messing with this? and didn't he post results?
To Throttle body question
