edelbrock cylinder heads
Old Nov 25, 2004 | 01:30 AM
bjcenter's Avatar
bjcenter
Default edelbrock cylinder heads
i am purchasing edelbrock performer cylinder heads and intake manifold...for a 1990 L-98...anyone have experience with these ,good or bad...what to look for, tips, tricks etc...thanks
Old Nov 25, 2004 | 02:47 AM
conv90's Avatar
conv90
Have you some part#?
For what I remember Edelbrock heads are with bigger combustion chambers 68cc or 74 cc compared to stock 113 heads (58cc). You will loose a good amount of compression ratio.
Old Nov 25, 2004 | 03:48 AM
ClarenceT's Avatar
ClarenceT
So what! Nothing a supercharger can't take care of!
Old Nov 25, 2004 | 04:45 AM
randy814u's Avatar
randy814u
I just bought a set, 64 cc, and from what I read I should go from 9.5 to just over 10 on a 85. Randy
Old Nov 25, 2004 | 05:55 AM
88BlackZ-51's Avatar
88BlackZ-51
what part #'s are these???
Old Nov 25, 2004 | 06:10 AM
pablocruise's Avatar
pablocruise
I had taken my AFR 210's to a local cylinder head/performance shop for some minor maintenance. I asked the guys there for recommendations on cyl heads and which ones to avoid.
They mention to have seen xlnt performance from canfield's, some brodix', AJPE's, and that my AFR's were just "ok".
The only one they told me to avoid were edelbrocks.
I know they work with all kinds of heads day in day out and work on the flow bench, so maybe they might be onto something. ???
Why are you ditching the stock D113's?
Old Nov 25, 2004 | 08:31 AM
conv90's Avatar
conv90
Yes, but bjcenter has a 90 with stock 113 heads that are 58cc combustion chambers.
Old Nov 25, 2004 | 09:13 AM
silver84's Avatar
silver84
Perhaps you could elaborate on why the perf shop
does not like Edelbrock. My suspicion is,
the shop's [told to customers] opinion of stuff it doesn't sell is:
that stuff is no good.
Old Nov 25, 2004 | 10:06 AM
vader86's Avatar
vader86
I wouldnt use Edelbrocks over the stock head in 90, just have the 90's heads ported.
Edelbrock heads are usually too close to them in terms of size to justify the expense. Unless youre picking one of the really big edelbrocks, like 210-220cc heads, which are probably too big for you anyway.
Old Nov 25, 2004 | 10:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
Edelbrock has improved a little over the years, but their heads aren't much of an improvement over stock. They're just now catching on to combustion chamber design.Just my opinion. Port the 113s
To edelbrock cylinder heads
