What is a frisbee?
Old Nov 25, 2004 | 09:45 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default What is a frisbee?
What is a Frisbee I hear people talk about?
Thanks Roger
Old Nov 25, 2004 | 09:54 PM
Nathan Plemons's Avatar
Nathan Plemons
On C4's equiped with the L98 engine there was some sort of additional device bolted to the front of the water pump. My gut tells me that it's some kind of vibration dampener and is there for a distinct purpose. On almost all accounts though you can ditch it without any ill effects and pick up one or two horsepower by reducing drag. Personally I think it probably decreases the water pump bearing life but I can't prove it. Other engines ran without it, what would make the L98 special to require it?
Old Nov 25, 2004 | 10:01 PM
vader86's Avatar
vader86
GM put it on when they changed compressors in 88, but I'm not exactly sure why, other than some engineer thought it was a good idea.
Its a big 10lb. weight added to the front of the WP in 88+ L98 corvettes. Its not harmful to remove it.
Old Nov 25, 2004 | 10:14 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Thanks Roger
In the 70s, they were popular among a certain segment of youth who threw them around in parks on warm afternoons because they were too stoned to participate in a real sport....... sorry.
Old Nov 25, 2004 | 10:27 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
If you don't know...I'll send you mine
Old Nov 27, 2004 | 02:05 PM
SunCr's Avatar
SunCr
It was put there to dampen the load of the a/c compressor. A few have posted vibration problems once removed, but most don't seem to experience this.
Old Nov 27, 2004 | 04:43 PM
ClarenceT's Avatar
ClarenceT
It's also more like 5 pounds, not 10, but makes getting the belt on and off easier, so I removed mine. No difference with or without here, so I'm glad I left it.
Old Nov 27, 2004 | 08:23 PM
tonymax2's Avatar
tonymax2
It was described as a vibration damper somewhere in one of the books I've read on C4's. If I run across that part again I'll give a more specific reference.
Old Nov 27, 2004 | 11:10 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
I'm currently building a collection of those things...Why....I have no idea except it's hard to throw away corvette stuff
Old Dec 1, 2004 | 05:23 PM
TommyVelour's Avatar
TommyVelour
Seems to me I remember throwing a frisbee around in the '60s - oops, I forgot, if you remember the '60s, you weren't there!
Old Dec 1, 2004 | 06:09 PM
Corvette Kid
Someday, when our cars are older, everyone will be wanting to return them to stock to maximize their value. You'll have the market cornered on frisbees!
To What is a frisbee?
