Have you guys heard of this working?
Will I experience the same problems of vibration like the Fadenza?
YOU hear alot of stories but I looking for facts!
depends on what you mean by a band aid. actually the real band aid IS the dual mass flywheel. I have the Fidanza alum one as well, it weighs 13 lbs. Anything much lighter than the 40+ lb. factory dual mass is going to rattle a little. The rattle is only a minor auditory nuisance thats all.
Here are the prs and cons in a nutshell:
dual mass
pros: quieter with ZF tranny.
cons: non-repairabale (can't be resurfaced successfully), horribly expensive to replace.
single mass
pros: less than 1/2 price of a dual mass, less wear on main bearings in engine, easily repairable, much faster revving, more hp transfered to the wheels.
cons: noisier rattle sound at idle (w/clutch disengaged), some experience minor noise in lower RPMS.
If you are talking about using a flywheel out of an '85-'88 4+3-speed L98 Corvette then no you can't - the bolt pattern is not the same. GM made alot of modifications (more than some people realize) in order to mate the ZF-6 to the L98 engine for 1989.
If you mean a flywheel out of an '89-'91 6-speed L98 Corvette, then yes you can. The engines are virtually the same during these years (with the exception of some modifications to the fuel system).
Personally, I went with a new dual-mass unit from GM for my '89. It cost me a small fortune to do it, but my car is basically all original, and I wanted to keep it that way. But if you are looking to gain some performance and loose a little bit of weight at the same time, then your best option would be to go with an aftermarket unit. Callaway made a nice one (I don't know if they still make it though) using a blank flywheel, meaning the holes haven't been drilled, from an '93-up F-body. It's probably your most cost effective option.
