Throttle Body gaskets
Old Nov 27, 2004 | 02:00 PM
91superram's Avatar
91superram
Default Throttle Body gaskets
Need a 58mm throttle body gasket dose Mr Gasket carry one
whats the part number
Old Nov 27, 2004 | 02:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you can't find one easily take a sanding drum on a Dremel to the stock 48mm gasket. If the gasket is a little more open than the TB bores it won't really effect air flow.
Old Nov 27, 2004 | 02:48 PM
FD2BLK's Avatar
FD2BLK
I just used a razor knife and cut it out.
To Throttle Body gaskets
