I have an '88 that came with the 16" cuisinart wheels (they have been sold) I now have the ZR! 17" wheels with 275s up front and 315s in back. The label from the factory calls for something like 35 psi front and back and that just doesn't seem right. Right now I have the rears at 30 psi and they still seem to be wearing more in the middle than on the edges. Any tips on proper tire pressure for this size wheel and tire?
More weight on the front end, so you need to compensate for the added "squish" factor to get even treadwear.
You'll probably think I'm insane; however, I run max pressures cold for the most part. Firestone SZ50 EP's at 44psi.
I've been doing this for years on other cars and this practice was only reinforced during my first driving in-service for work a couple of years ago.
We are instructed to run max pressures on our cruisers for temperature dissipation and high speed operation. I drive that Crown Vic like I stole it all shift long and get great even treadwear and much improved handling.
Then again...this is just my experience.
Interesting... but I bet it KILLS ride quality. Then again, if we were concerned with ride quality we wouldn't drive Corvettes
Yes I run higher up front for handling traction and to reduce edge wear during hard cornering and I run lower out back for better hookup on the street. I find that 28-32 psi works best at the strip.
For your rear tires you might try doing a burn out and checking darkness of the strips from edge to edge. Adjust pressure for a uniform stip. This works well when setting up for the drag strip but not sure how it would do for street driving.
I like to run 35 all around. A little stiffer ride but better gas mileage. Also handles better. I ran under 30 for a month and the results are as follows: Softer ride.
Bad gas mileage.
Rear tire blowout.
I'll stay with 35 all around, thanks.
