Need Help with Spark Plugs - '87/L98
Old Nov 28, 2004 | 05:04 PM
BamaVette87's Avatar
BamaVette87
Default Need Help with Spark Plugs - '87/L98
This is my first time to change out the plugs on my 1987 L97 engine (stock). Helms says that the plugs are supposed to be tapered. The owner's manual says to use FR3CLS. The newer Delco xref to the FR3CLS is a 41-629 (that's also what is currently in the car). Bought 8. They are not tapered! Should I be using a different plug?
Old Nov 28, 2004 | 05:24 PM
CFI-EFI's Avatar
CFI-EFI
Are you looking at the SEATS??? There are tappered seat plugs and gasket seat plugs. The new plugs have gaskets???
RACE ON!!!
Old Nov 28, 2004 | 05:47 PM
BamaVette87
The new plugs have gaskets. They are not tapered as I had expected after reading in my Helms manual.
Old Nov 28, 2004 | 07:41 PM
BamaVette87
I just read somewhere that GM discontinued recommending tapered-seat sparkplugs for aluminum heads because they tended to freeze up and were difficult to remove.
Do we have any spark plug experts out there who can chime in on this??
If I now have to use the gasketed spark plugs, what torque do I use. The recommended value for the tapered plugs (22 ft-lb) would no longer apply.
Old Nov 28, 2004 | 08:21 PM
Pete K's Avatar
Pete K
The 41-629 is the correct plug for your 87. It replaced the discontinued fr3-Ls.
Old Nov 28, 2004 | 08:25 PM
rick lambert's Avatar
rick lambert
well its been awhile since I changed the plugs on my 87, a year or so, can't remember about the taper part. But, I for one have never used a torque wrench on plugs, just tightened til snug+. Curious how many guys actually torque them-been doing tune ups for 40+ years.
Old Nov 28, 2004 | 09:20 PM
Dogs 86 Vette's Avatar
Dogs 86 Vette
St. Jude Donor '05
however I do put antiseize on the plug threads also.
Bob
Old Nov 28, 2004 | 09:22 PM
JackDidley's Avatar
JackDidley
I have an 87. It has the 41-629. Just be sure and put a bit of antisieze on the threads.
Old Nov 28, 2004 | 09:50 PM
BamaVette87
Thanks for the response, everyone! I'm glad I didn't buy the wrong plugs! Will be putting them in tomorrow night (if I can figure out how to get #2 and #8 out!).
As for torquing things down, I'm not very mechanically minded. I can follow directions, but I'm not good at ad lib'ing. So, for me, something like "snug, but don't overtighten" leaves me in the dark! But "torque to 22 ft lbs" is very clear.
Hope everyone had a wonderful Thanksgiving!
Old Nov 29, 2004 | 10:54 AM
rick lambert
Sorry, when I say snug-I generally tighten them with a ratchet to the point I know there seated well then give it a 1/4 turn more. 20 pounds is not alot of pressure-if you have a bathroom scale-push it with your hand and watch it climb to 20 lbs. I guess it's just having done it so often it becomes second nature.
Old Nov 29, 2004 | 03:26 PM
BamaVette87
Thanks for the explanation, Rick! That makes it easier!
Old Nov 29, 2004 | 10:46 PM
BamaVette87
Thanks everyone! Changed my plugs today. The #2 plug had the electrode almost touching the post (about .10 mm clearance). Maybe somebody had dropped it on the ground before installing it?? The #5 plug looked black. But this is the one where I had previously found the wire boot not pushed down all the way on the distributor cap. All the rest were picture-perfect (slightly brownish around the base and on top of the electrode).
Put the new ones in and they made a world of difference! (Coffee doesn't splash out of my cup at idle any more!!!!)
With a few PM's from some of you, I got some great ideas about reaching #2 and #8. I was able to go through the wheel-well opening to get #2 (never noticed that opening before!) and I used an open-end wrench on the back of the sparkplug socket to get #8.
Another job learned with help from forum members! Thanks all!
(Found this link to spark plug pictures...
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html )
To Need Help with Spark Plugs - '87/L98
