trans coolers
Old Nov 28, 2004 | 06:57 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default trans coolers
Ok, how and where did you mount your auto trans cooler? Did you use those zip tie things through the condensor, or bolt it up somewhere?
Old Nov 28, 2004 | 07:15 PM
CF6873's Avatar
CF6873
I put mine between the condensor and the rad. I used the plastic ties that came with it and attached it to the condensor. It was easy to run the lines out the side into the right headlight well and then under the frame rail and up to the radiator connections. Also the top trans line to the rad is the one to feed the cooler.
Old Nov 28, 2004 | 07:30 PM
POLOVETTE 94
Are you sure you use the top line, not the bottom one? I thought the cooler should be connected after the radiator's cooler. Isn't the top line the in line to the radiator, and the bottom one the out line?
Old Nov 28, 2004 | 07:50 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Nov 28, 2004 | 08:01 PM
CF6873's Avatar
CF6873
My mistake, You are correct. Craig
Old Nov 28, 2004 | 08:04 PM
POLOVETTE 94
That's a good thing, as I just ran my hoses this afternoon, to the bottom line! Thanks for the reply, so I can go to sleep tonight
Old Nov 28, 2004 | 08:52 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
What kind of trans cooler is that and where did you get that. I need one for an 89 auto.
Thanks,
Ed
Old Nov 28, 2004 | 09:36 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I'll go beyond this even... why does anyone need a trans cooler? I autox my 93 auto, is it absolutley necessary to have one? Doesn't is seem that the factory would have thought of this when designing a performance car? TIA...
Old Nov 28, 2004 | 09:42 PM
Mr Mojo's Avatar
Mr Mojo
I put a high stall converter in, it's much smaller so it has less fluid, less fluid = more heat.
Ed(fastzr1), the one I have pictured is a B&M, I forget the specs, but it's either a 19,000 or 24,000 lb cooler, got it from Summit.
Old Nov 28, 2004 | 09:57 PM
vette92_1's Avatar
vette92_1
I made up some bracketts out of some metal bands I had laying around. Pretty much placed mine in the same location as Mojo's.
Mounted Cooler
Old Nov 28, 2004 | 10:26 PM
CF6873's Avatar
CF6873
The only reason I put a cooler on is for track days. I did a day at Summit Point in August and the fluid was cooking out of the pan. I put the cooler on right after that.
Old Nov 28, 2004 | 10:27 PM
eschoendorff
St. Jude Donor '08
Okay, that makes sense. But if I have a completely stock transmission and the only remotely interesting thing that I do with the car is autox on the weekends, is it really necessary in my case?
Thanks,
Ed
BTW... Mojo... are you attaching your brackets to the bolts that mount the air dam? If so, where are you securing the brackets at the top? (couldn't see from the pics... need to take out contacts and put in glasses maybe... )
Old Nov 28, 2004 | 11:19 PM
vette92_1's Avatar
vette92_1
I struggled with this same thing before I put a cooler on and I don't even auto cross, but like Mojo, I did have a higher stall put in. But anyway, what ultimately made up my mind for me was a comment that was made on this forum. And the comment was in the form of a question:
"How many transmissons do you know of that have had to be rebuilt because they were running to cold?"
Believe it or not, I actually called a few local transmission shops and asked them that exact question. Not surprisingly, not a single one said they had ever "to their knowledge" had to rebuild a transmission that could be linked to running to cold.
So with that, I thought, what can it hurt? It's a realitively cheap addition, and if nothing else I know it shouldn't over heat.
Old Nov 29, 2004 | 05:42 PM
guywade's Avatar
guywade
Default i totally agree
totally logical mr. spock! the same reasons i need one also .
Old Nov 29, 2004 | 06:45 PM
Mr Mojo's Avatar
Mr Mojo
I was installing the Big Mouth when I took those pics, I undid all the bolts to move the cooler out of the way. Your eyes are good.
Old Nov 29, 2004 | 09:14 PM
jpee's Avatar
jpee
You should know there are 2 types of coolers 1) Stacked Plate ...2) finned tubing..
I had the finned type & my trans ran about 200 deg... I switched to the "Stacked Plate" and now it runs 180deg..
GET the STACKED PLATE Much better...
Old Nov 29, 2004 | 09:52 PM
POLOVETTE 94
With the stacked plate design, does it matter which way the fittings face? I know to lay the cooler on the condensor, the same way as the condensor and radiator, but does it matter if the hoses attach at the top, bottom, or side? I guess the fluid will be pushed through either way, right? I was going to mount mine with the lines facing the passenger side, so they will be shorter/easier to run.
To trans coolers
Old Nov 29, 2004 | 09:57 PM
jpee's Avatar
jpee
Nope mount it anyway that is easy...good luck I know you'll be happy with it..
Old Nov 30, 2004 | 12:25 AM
pablocruise's Avatar
pablocruise
I saw this in tech tips about using the A/C condenser as a oil cooler if you are not using the A/C system at all:
https://www.corvetteforum.com/techti...=234&TopicID=2
hmmm......
Old Nov 30, 2004 | 08:04 PM
Mad-Mic's Avatar
Mad-Mic
i got the biggest Hayden cooler they make. i think it's 36,000 lbs..
i did have to make 1 custom line because i used the radiator stock cooler also and jus piggy backed the new cooler.
