Final performance question.....Intake..
Old Nov 29, 2004 | 07:17 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Final performance question.....Intake..
So I am narrowing down my choices for headers and intake. This is an intake question.
I am leaning to the LPE super ram. Anthing I need to know before getting started.
Also, a friend warned me that snapping bolts on the intake manifold is not uncommon when trying to get them out of the heads. Anyone else have this problem?
Thanks again!
Old Nov 29, 2004 | 08:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It's not likely that you will snap either intake or exhaust bolts getting them out of Al heads. If you have iron heads hit the bolts with some PB Blaster the night before.
Old Nov 29, 2004 | 09:02 PM
jsup's Avatar
jsup
Allow me to be stupid. The last CSB I built was in my 74 C3. I knew exactly what I was dealing with. However, in this case I'm learning.
So, at the risk of sounding like an idiot......1990 L98 has aluminum heads, right?!
Old Nov 29, 2004 | 09:22 PM
85vet's Avatar
85vet
Cruise-In V Veteran
jsup,
Send me an email at vet85us@yahoo.com and I will send you faqs and tips on the SR that I have accumulated from this forum.
Old Nov 29, 2004 | 09:28 PM
bmalec's Avatar
bmalec
Correct, aluminum heads on a '90 L98.
Ben
Old Nov 29, 2004 | 09:56 PM
65Z01's Avatar
65Z01
Yes you have the D-port #113 Al heads so, though the intake bolts may be a little tight (they have Permatex #2 on the threads) they should not break off upon removal.
Old Nov 30, 2004 | 06:13 PM
Vic'89's Avatar
Vic'89
They are only torqued to 35 lbs, they should not break.
Vic
To Final performance question.....Intake..
