92 Alt plug replace ??
Old Nov 30, 2004 | 09:06 AM
Strick's Avatar
Strick
Default 92 Alt plug replace ??
I was replacing my valve covers and broke the plastic plug that goes into the alternator. Can this plug be replaced? Where would you get one besides a junkyard?
Old Nov 30, 2004 | 09:27 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Tom, is this the one?
Old Nov 30, 2004 | 09:38 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Yeah mine just kind of fell apart in my hands when I pull it out last week. The one on mine is a three wire that plugs into the lower side of the Alt. I will be going over to the dealership tonight to find out if I can get one that just has some short leads off it that I can splice into the harness.
I'll let you know what they say tonight when I get home.
Is this the same one that you need? (three wire)
Old Nov 30, 2004 | 11:46 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Yeah mine on my 92 broke also. What broke on mine is on the alternator itself, so uless I want to buy a new one, its gonna be that way. I justmake sure its snugly fit on there and it hasn't given me any trouble sofar.
Old Nov 30, 2004 | 02:21 PM
Nathan Plemons's Avatar
Nathan Plemons
Gotta love 12 year old plastic don't ya? Ecklers actually has a pretty good selection of repair connectors that I've used some of. Most of them come with new pins and all but I've found you don't usually even need those. I've repaired several by just carefully removing the pins from the old plastic housing and putting them back into the new housing.
BTW, wait till you go to remove the positive lead from the alternator and the stud turns inside the alternator housing! Then you get to take the thing apart and tighten that lug back up, then figure out how to put it back together.
It's really not hard to do, just annoying. You've got to use a neat little trick on the brushes too but overall it's not too bad.
Old Nov 30, 2004 | 03:46 PM
Strick's Avatar
Strick
Not quite. It looks like it uses the weatherpack type connector. I just ordered one from Eckler's $11.99!!!!!!!!!!
Old Nov 30, 2004 | 09:16 PM
Nathan Plemons
Yeah that stuff can be pretty expensive but sometimes it's worth it.
Old Nov 30, 2004 | 10:19 PM
Ramrod92's Avatar
Ramrod92
Is this it?
Old Nov 30, 2004 | 10:24 PM
Strick's Avatar
Strick
Is this it?
Yep, that's what it looks like, but I think it has 3 wires, 1 large and 2 smaller ones.
Old Dec 1, 2004 | 03:51 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I thought I only broke those things try NAPA $35.00
Old Dec 1, 2004 | 07:36 AM
fsr402's Avatar
fsr402
St. Jude Donor '06
I was not able to get to the dealer last night and I look online but I did not find the plugs. Do you have a part number? the three wire one.
To 92 Alt plug replace ??
