Pke Module
Old Nov 30, 2004 | 08:22 PM
redruby93's Avatar
redruby93
6th Gear
Default Pke Module
My 93 Ruby Pke Quit Working ,dealer Said The Pke Module Nees Replaced. Has Anyone Tried To Replace This Module That's Behind The Dash. ???? Sounds Like A Good Winter Project...
Old Dec 4, 2004 | 09:17 AM
93poloboy's Avatar
93poloboy
3rd Gear
Default it's dooable
I repaired my 93 pke 2 weeks ago. Gettinng to it requires removing the top portion of the dash. Helm was a great help with this. It took about 2 hours to remove dash and related itemd. Once that is removed it's 2 screws and a clip away from being out. BTW my problem was a bad solder connection from the connector to the board. This caused the locks to stop working via pke or switched. Resoldered and everything is peachy now. Good luck.
Old Dec 5, 2004 | 06:49 PM
redruby93's Avatar
redruby93
6th Gear
Thanks For The Info. Will Try To Work On It In The Near Future After Christmas.
To Pke Module
