Multiply or Divide?
Old Nov 30, 2004 | 08:23 PM
FD2BLK's Avatar
FD2BLK
Default Multiply or Divide?
I know this kind of a retarded question but I am curious do you multiply or divide to convert RWHP into FWHP. I would think that if there is 16% drive train loss (just a guess BTW) that the answer would be dividing but am not sure. For instance if my car made 414 RWHP you would say that it is 84% of the FWHP so 414/.84=492.86 –vs - 414x1.16=480.24
Old Nov 30, 2004 | 08:33 PM
#70SM2's Avatar
#70SM2
Default Whats FWHP?
Whats FWHP?
414 X .84% = 347 CHP. HP at the crank.
Old Nov 30, 2004 | 08:36 PM
VenkmanP's Avatar
VenkmanP
Yes you divide by 0.84. The reason is that the original 16% number was referenced to the FWHP.
Multiplying by 1.16 would mean that you have 16% more FWHP than RWHP, which is not the same as having 16% less RWHP than FWHP.
Old Nov 30, 2004 | 08:38 PM
#70SM2's Avatar
#70SM2
Default Whats FWHP?
480 HP at crank (CHP)
Old Nov 30, 2004 | 08:39 PM
VenkmanP's Avatar
VenkmanP
Wait a minute. Your profile says you're an electrical engineer...
Old Nov 30, 2004 | 08:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Ok, assuming 16% DT loss, RWHP must be 16% lower than CHP, or
RWHP = CHP - CHP * .16 = CHP * (1-.16 ) = CHP * .84
so,
CHP = RWHP / .84
In your example you have 414RWHP, so you would have:
493CWHP = 414RWHP / .84
Old Nov 30, 2004 | 09:00 PM
Nathan Plemons's Avatar
Nathan Plemons
Yeah so, I'm to be a mechanical engineer and I just got finished with my statics homework. It SHOULD have taken and hour to do it LAST night. I just finished it today. It literally kicked my *** and it was nobody's fault but my own!
We all have our moments.
Old Nov 30, 2004 | 09:07 PM
#70SM2's Avatar
#70SM2
Wow, I don't feel so bad now, I never got past my Engineering Science degree, I just figured the calculators were old technology.
Old Nov 30, 2004 | 10:24 PM
FD2BLK's Avatar
FD2BLK
I just wasn't sure if the reference was actually stating that there was 16% drive train loss (Roughly) or if they where calculating for drive train loss by multiplying by 1.16. I have seen it posted both ways and never seen an actual formulation or dyno results either way. I planed on building a 500 HP motor when I started and feel there is a little left in tuning so I was hoping for the / rather then the *. My car had a miss the day we tuned and it made for a long day so I think with another day of dyno tuning it could make 420 RWHP and close to 420 RWTQ. Thanks for all the input
Old Dec 1, 2004 | 10:16 AM
JCD's Avatar
JCD
Err, 16% drivetrain loss means that if you have 100 CHP you'd have 84 RWHP.
So to go from RWHP to CHP you have to multiply RWHP by 1/(1-16%) [or whatever percent your drivetrain loss is] which is about 1.19 in this case.
so 84 RWHP * 1.19 = 100 CHP
and in your case:
414 * 1.19 = ~493 CHP
65Z01 gets the prize.
Old Dec 1, 2004 | 12:03 PM
Red Tornado's Avatar
Red Tornado
this might sound really stupid, but would the formulas apply whether your talking 100chp or 10,000chp as the basis?
ex: assuming 16% total loss: 100chp * .84 = 84rwhp
1000chp * .84 = 840rwhp (is it really THAT much of a loss?)
just seems to me there's some additional factoring of some kind (ie, not a linear equation) that comes into play as the chp goes up. maybe i'm just confused like i normally am
Old Dec 1, 2004 | 12:34 PM
Nathan Plemons
No you're not confused. I don't put a lot of stock in crank horsepower numbers for this very reason. I always quote rear wheel horsepower numbers because that is what can effectively be measured. Drivetrain loss is not even close to being linear so it's really a very poor estimate. Take your pick of a "correction factor" and it will be wrong PERIOD. The only way to really know what your engine puts out at the crank is to put it on an engine dyno. That's a little bit difficult to do so people like to try and guess with correction schemes, but they really are just guessing.
Old Dec 1, 2004 | 12:45 PM
Red Tornado
ahh, thanks Nathan, that makes perfect sense
Old Dec 1, 2004 | 01:46 PM
JCD's Avatar
JCD
finding a dyno wasn't so hard, and once you get the numbers you have a stronger basis for figuring out your acceleration and top speed (there's still some handwaveing, but less so).
Finding your top speed in real life is more difficult (and generally not legal), so I'll live with my educated guess and maybe someday I'll get to test it out...
Old Dec 1, 2004 | 05:14 PM
Atok's Avatar
Atok
Good explanation.
To Multiply or Divide?
