Oil Everwhere !!!!!
Old Dec 2, 2004 | 08:30 PM
Kens86's Avatar
Kens86
Thanks for the timely follow-up!
Mash 557 - Email address fowarded. Thanks in advance for providing the pics.
Old Dec 2, 2004 | 09:23 PM
mash557's Avatar
mash557
Ken, you have mail!!
Going to try and insert pictures so everyone can see.
The large sender with 1 terminal in the oil pressure sender, the smaller one with two terminals is the oil pressure switch. This should be the proper orientation.
Old Dec 3, 2004 | 10:02 PM
Kens86's Avatar
Kens86
Mash 577 a thousand thanks for the Pics !!!!! Looks like a last minute engineering fix! We now know what we are going after.
After spending more time looking around in detail under the hood and checking my records I realized that 9 years and 15k miles have past since any real work has been done on the motor.
The $10 dollar part will now become the following project.
Replacement of - Plugs, Wires, Rotor, Cap, Wire clips, Valve cover gasket, oil sending unit and pressure switch. While we are at it a fresh coat of paint for the valve covers.
If I have to dive in might as well go all the way. If there is anything else I should consider while I'm that far in let us know.
Thanks all again for the help.
